Question about Neff K4664 Top Freezer Refrigerator
How do you it a cabinet door to integrated fridge door
Fisher and paykel fridge is making a whining noise only when door is closed. Thanks in advance.
If this is a large cabinet or larder fridge the cabinet is not rigid enough to maintain it's shape unless it rigidly stands level and square. It can take a deal of time and effort to adjust the front feet in order to level and square the cabinet on a relatively flat floor and sometimes it is impossible without first preparing the floor.
It is important for them to stand level and square and at the same time stand firmly on all the feet. If they are allowed to operate out of plumb for any length of time the motor/compressor unit can soon become noisy. Often this is only noticed when the door is closed or open. The door is a major part of the rigidity of the modern fridge and if the fridge is not properly levelled the shape of the cabinet will change as the door is opened and closed causing any compressor noise to be transmitted differently.
The gas charge of the modern fridge can also make weird noises as it is being pumped around the circuit. Ours sometimes sounds like the wind blowing across an open chimney and sometimes like the sea breaking on to a pebble beach and sometimes like something sprung a leak. All this is fairly normal after the fridge has lost it's youthfulness.
Jul 23, 2016 | Fisher and Paykel Refrigerators
How do I replace the bottom socket where the door hinge slides in
I assume you mean the hinge that is on the cabinet and not the door? If its the door part that has failed, you will need to get a new door. If its the cabinet hinge, some of these are screwed onto the cabinet from underneath the fridge. Others however, are mounted inside the cabinet and are not really designed for replacement. Ive fixed a few over the years on different brands where the plastic hinge has broken but it can be a bit messy. The cabinet needs to be carefully peeled or bent back on the bottom corner of the fridge to access where the hinge is mounted. Unscrew the hinge and if you are lucky, the Manufacturer has these as a spare part. If not, the only way is to go to a hardware or cabinet parts store to try and source something that will suffice. Do NOT be tempted to put a normal gate or door hinge onto the fridge door and screw it onto the cabinet. Inside the cabinet especially around the edges are whats called "mullion heater" pipes or in older fridges, mullion elements. If you screw through a pipe, you will lose the gas and fridge will be shot. If you screw through an electrical mullion heater, there is a danger of electrocution.
Dec 23, 2014 | Dometic RM2852 Refrigerator
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
Is there a video which will show me how to fit a CATA fridge freezer into a cabinet?
As any integrated cabinet, you have to measure the dimension of the Freezer and create a space a little wider say 1/2 inch on each side and on top to make sure you can slide it in
http://www.thegascompany.ie/iopen24/images/content_images/hotpoint_built_in_ovens/hotpoint_60_int_dishwasher_drawing.JPG
After you can nail down moldng around it
Do not forget to install an electric outlet to plug it in ;)
Jun 05, 2014 | Refrigerators
Suction of freezer door
No, that perceived suction effect is the magnetic door seals 'grabbing" onto the fridge cabinet and pulling the door(s) shut firmly and securely.
Typically as the fridge gets older, you'll need to clean off both the fridge cabinet edges and the door seals to maintain a proper seal, which is essential to keeping the fridge operating properly.
Hopefully you find this Very Helpful and best regards!
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge is not keeping cold
I will need a little more information to help you better,
Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 26, 2009 | Refrigerators
Refrig door hits cabinet
If you change the hinge you will void warranty on the unit. Really just be careful when you open the door.
Mar 23, 2009 | U-Line Origins 1175R Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Neff K4664 Top Freezer Refrigerator Logo
23 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
