Question about Samsung Computers & Internet
Liebherr k4220 power is not getting to the compressor
My Liebherr Fridge / freezer has just stopped working. The light is on but there is no refrigeration, it is only about 4/5 years old. Help!
It is a technical problem more than likely but will require someone who can use a voltmeter. If the compressor is running then it is probably out of freon.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 01, 2018 | Liebherr Refrigerators
After power outage with a power surge. Our two Liebherr CS1311 are only blinking double dashed lines for the freezer temp and nothing seems to be working other than the lights and control panels.
If the compressor happened to be running when the power surge happened, it's possible the motor inside the compressor has failed. There are safety devices on the compressor that may have gone bad too. The electronics in the controller don't do well in surges, so that may be the problem too. It all comes down to how much the repairs will cost added to what you already have done to it against the cost of a new unit.
Dec 05, 2016 | Liebherr Refrigerators
Very noisy Liebherr CN4013-21 - 4 years old
Might be, the compressor is loose, now is it loose at base where it is fastened or the bearings are loose.
Dec 16, 2013 | Samsung RS2630WW Side by Side Refrigerator
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
I own a liebherr GNP2076 frost free upright frrezer
freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
Apr 06, 2010 | Freezers
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
My fridge is too cold
I wrote under "guest" earlier on Aug 5th. I jave since discovered that the problem is a manufacturer problem. Apparently Liebherr had problems with their sensors, which they have since corrected, but they were put in all the earlier fridge/biofresh. I contacted the Liebherr agent in Melbourne Australia where mine came from (Andi-Co), and they have sent someone out to replace the sensor free of charge (mine has been out of warranty since March 2008). The sensor tells the compressor when to shut off, and when faulty does not do this so the compressor keeps running and freezes everything. I did have to make a bit of a fuss though and write them a letter before they came out. I printed out this page as evidence that it was clearly a manufacturing problem, which they have now confirmed. So I suggest you ask your supplier to fix the problem free of charge. Good Luck!
Apr 30, 2008 | Liebherr K 4260 Refrigerator
Fridge and frezeer not working
Liebherr embraco compressor....compressor fluid leaked while moving, what is the fluid? is it easy to replace?
Dec 06, 2007 | Liebherr KTS 1534 Comfort Compact...
Computers & Internet Logo
26 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
