I have a toshiba laptop satellite C855-1W7 when i switch on the screen is blank have you any idea's please
geminii_lady
  • 87 Answers
SOURCE: Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Posted on Nov 22, 2008
fidoliedo
  • 162 Answers
SOURCE: toshiba laptop satellite A100-332
Toshiba has a problem with the connector from the LCD to the board which breaks over time. You will need to replace it. Here is a sample of what the part looks like. You will need to specify your model.
This one is from a DELL, the one below is from a Toshiba. This went bad even though the client never used the notebook as a portable. It sat on a desk for years and was never moved.
Posted on Nov 26, 2008
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
Posted on Jul 23, 2009
  • 5 Answers
SOURCE: Toshiba Satellite A210-11p.Screen is blank.Does
Take a flashlight and shine it into the screen once PC is powered up. If you can faintly see your computer booting up in the background you probably have a bad LCD inverter card. They go for under 10$ on E-bay. Cheap and easy fix if that is the problem. Good luck, Todd
Posted on Dec 22, 2009
SOURCE: TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
I found that while running on battery, disconnect the battery after it starts up by itself. When the battery is plugged back in the computer remains off. Now the power setting work as they should.
Posted on Aug 04, 2012
Laptop powers on but goes to a blank screen and stays there
Your problem could be a backlight problem, it is caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instruction to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 14, 2010 | Toshiba Satellite A45-S151 Notebook
Have a Toshiba Satellite A210-1C0 and it has started to have a black screen issue. The PC is still running but screen is black.....any ideas??
Try updating the BIO via http://support.toshiba.co, there have been a few issues on the Satellite's with the system going into monitor blank power standby when it's not supposed to.
Jun 11, 2010 | Toshiba Computers & Internet
Dec 22, 2009 | Toshiba Computers & Internet
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Toshiba lap top screen goes blank
My laptop got problem with the interface the screen appear like gray.
Dec 15, 2008 | Toshiba Satellite M115-S1061 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
