Question about LG Televison & Video
CRT RPTV B&W image composite input
I have a CRT Rear-Projection TV. When I try to input composite video (on any port) it flashes briefly in colour, then the image turns black and white.
    Top Expert:
  • LG Master
  • 74,383 Answers
How many times this standby/power light blinks at one time Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 19, 2013
jerryg50
  • 1667 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Posted on Apr 28, 2008
SOURCE: Black and white on av channels?
fixed problem by replacing board on control side
part sourced for £85
now all ok
Posted on Jul 10, 2008
cjackHD
  • 71 Answers
SOURCE: Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Posted on Jun 01, 2009
  • 4234 Answers
SOURCE: Black & White Picture in different input modes
Can you describe the connections please? I suspect that the DVD +/or WII is outputing component video and you have it connnected to composite video. Please diagram the conenctions.
Thanks,
Dan
Posted on Aug 21, 2009
HOOK UP VIDIO SURVALENCE CAMERA TO BACK OF TV
The camera output would have to be composite---and if so go to one of the rear audio/video inputs: yellow (composite video) is likely all you would need unless the camera has audio as well (go to red or white on same input).
Jun 02, 2012 | Hitachi 43UWX10B 43" Rear Projection...
Hooked up a wii to front av inputs. I have no wii
Make sure the Wii's analog composite video output is enabled. Try resetting the Wii to factory defaults. this will default to enable the composite video output.
You can find the procedure in the Wii manual.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
How can i watch movies from computer to my tv
You probably need to get a composite video output card for your computer. Actually, I've seen many cards that have both a composite video output AND a DVI output port on 1 card. The DVI output will give you a noticeably sharper picture than composite video, but you need to check if your TV has a DVI or HDMI input. (If it was manufactured after 2000, it probably does.) If you TV was manufactured after 2006, it probably has 1 or more HDMI inputs instead of DVI. You can buy a DVI to HDMI converter cable. That takes care of the picture; to get sound to the TV, you will need to connect separate sound cables to your TV. Your computer needs to have a line-level output jack on it's sound card, and you will need to get an adapter cable (from Radio Shack) to convert the stereo mini-plug to 2 RCA type plugs to plug into your TV. And that should do it!
Dec 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Yamaha DSPAX761 no s-video to HDMI
S-Video and Composite are analogue and HDMI is digital. Your receiver dose not have the capability to convert from analogue to digital and hence you are not not getting any video.
Feb 28, 2008 | Televison & Video
No Image though Composite hookup
call a local repair technican or try different devices
Dec 10, 2007 | Philips 36PT842H 36" TV
Mitsubishi rear projection
On every input?? RF (coax),yellow(composite),S-Video and
component (red,green,blue)??
Verify model # please......T.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Picture of rear projection tv
Convergence amp ic are bad.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
Oct 13, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv below listed on ebay i'm interested in buying not sure if worth or what repair would be?
Depends on how much do they want for set repair cost verys anywhere from 250 up to 375.00.Set might only need to realine convergence on customer level.
Sep 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Video Input
Are you sure that the source is generating a video signal? It is extremely rare for both front and rear Video Input sockets to fail simultaneoisly. from your description, i would suspect the cable connecting the Viseo out of your DVD player / Video Game than the Video Input ports of the TV. If you have another cable, just try again with that. Or, try using the Red to red cable into the Yellow port, using one end at the DVD player and the other at the TV Video Input. If there is image, then it is confirmed that the cable is faulty, and you can get a replacement cable for a few bucks at any Video store.
Mar 20, 2007 | Symphonic ST419E TV
Televison & Video Logo
20 people viewed this question
Computer Repairing
Computer Repairing
