Bypass led is lit on UPS 2000TR-III - Computers & Internet
3 Suggested Answers
  • 2567 Answers
SOURCE: bypass LED on the ups is on
This an excerpt from the UPS's manual:
The Bypass LED illuminates indicating that the UPS is in bypass mode. Utility power is sent directly to connected equipment during bypass mode operation. Bypass mode operation is the result of an internal UPS fault, an overload condition, or a user initiated command through an accessory. Battery operation is not available when the UPS is in bypass mode.
Posted on Jul 19, 2009
mestrada642
  • 21 Answers
SOURCE: internal problem galaxy 3000 ups
The question is not clear... which of the LED`s are lit?? green, yellow, red.is there a message on the screen??
Posted on Jul 12, 2012
NO VOLTAGE ON YELLOW PHASE
what caused the UPS to transfer to Bypass? could be inverter fault, would you please check your battery set, maybe the input power is outside the tolerance and causing UPS to discharge the battery set , as well when battery set reaches the end of discharge it is causing the UPS to transfer to bypass and there is something missing on the input yellow Phase.
if the above is not true check the load type that is connected to the UPS output that is causing UPS to switch off in 10 minutes time.
Apr 17, 2014 | MGE UPS Galaxy 3000 UPS System
No output
You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Mar 25, 2014 | MGE UPS Galaxy 3000 UPS System
The ups turns on, all the led light lit at the same time. what's the problem.
I believe you will find that your battery is either dead or shorted.
Aug 09, 2012 | Eaton Powerware® 5110 UPS System
Internal problem galaxy 3000 ups
May 18, 2012 | MGE UPS Galaxy 3000 UPS System
UPS for LED tv
The set need a UPS with minimum 500W load capacity
Apr 02, 2012 | Sony 55 KDL55EX720 3D LCD TV
I have a UPS Smart 5000va model :surtd5000xli I replaced all new battery for ups but when i started ups all leds in the battery column litting .I want to connect ups and pc to reset new battery (this ups...
Unplug your UPS from the wall. Disconnect the batteries. Push the on button. LED's may flash. This is how to reset the logic. Connect the batteries and plug back in. Everything should be reset.
Aug 03, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Symmetra LX "Intelligence Module Fault". Does
First calculate the total load of the UPS and then calculate the total load. One of the Intel Module is Primary and one is Secondary. I can't remember exactly which one is primary. Q1. There will be a LED on the INTELI MODULE flashing RED. That identifies the bad MODULE. Q2. You can remove the MODULE, but I recommend you place the UPS in Static Bypass first through the Display Menu. Also make sure the UPS is in NORMAL MODE or already in STATIC BYPASS, the LED's on the Display should indicate what mode its in. Q3. You can remove the display from the Inteli Module with out harming the load. You just can't do anything with the UPS, as to tell it to Go to Bypass (Static Bypass) or get out of Bypass, check voltages, etc. So order the part first by getting part number on the sticker off the Module, then schedule your shutdown and perform the you maintenance after hours this way you don't affect anything during business. Also don't do the repair on a Friday due to the fact its weekend and APC/Third party UPS companies will charge you a lot to come out in the weekends. FIRST DO THIS PLEASE- GET THE MANUAL FOR THIS UNIT!!!! And READ IT FIRST!! Find in the manual where it walks you through putting the UPS In bypass (Static Bypass). Follow the manual, My way of doing is to READ TWICE, OPERATE UPS ONCE!! This has help me not dump any loads. My suggestion to you is to check if unit is in Bypass (static Bypass due to the faulty module. If it is on Bypass then all you need to do is follow the procedures to place UPS in External Maintenance Bypass. If UPS is in Normal mode but with Alarms and Beeping, then Navigate through the display and find the BYPASS Mode. Then hit enter Yes on the BYPASS MODE, it will ask you again if you want to "Place UPS INTO BYPASS. Hit YES. You will hear it click. Your LED on the display should Light UPS Solid "BYPASS LED ON" AGAIN Please keep referring to the MANUAL. Once your in bypass mode (Static Bypass) then you can operate the External Bypass Switch on the bottom of the UPS. That is the Maintenance Bypass Switch. This isolate the UPS completely and your load never see's the transfer from Static Bypass to External Bypass, Because its a MAKE BEFORE BREAK System. (Make the power before Breaking the Power) Sorry to get down to simple terms, but when I work on a UPS its personal due to the fact you are responsible for the all that is on the OUTPUT of that UPS. Once on External Bypass, You can now do you module swap. Turning the UPS back on, Please follow place UPS back On Line in the UPS Manual. Also in the Diagnostics, off the display of the unit, it also identifies what module is bad including the Power Modules to the Battery Modules.
Nov 03, 2010 | APC Symmetra Tune-UPS technical support -...
Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Oct 21, 2009 | APC Back-UPS XS900 (BX900) UPS System
Bypass LED on the ups is on
Jul 19, 2009 | APC Smart-UPS 1000VA UPS System
Computers & Internet Logo
David Payne
David Payne
