Question about Hitachi HTS541612J9SA00 120 GB SATA Hard Drive
Hitachi hdp725016GLA 380 ATA DEVICE - Hitachi HTS541612J9SA00 120 GB SATA Hard Drive
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
Is Hitachi 320GB SATA 2,5"
you perches ata to sata connector or sata to ata connector
Sep 07, 2011 | Hitachi 320GB SATA 2,5" HTS543232L9A300...
I'd like to use my Hitachi HTS5410 hard drive as an external USB drive. I can see it in the Device Manager but it does not appear in My Computer. What is the problem?
TRY IN COMPUTER MGMT THERE ARE OPTIONS THAT MAY HELP YOU, IF IT DOES NOT SHOWUP IN "MY COMPUTER" THEN MAYBE THERE IS A OS STILL IN THE DRIVE,THEN YOU WILL HAVE TO FORMAT.......USUALLY NTFS.......OR ERASE DRIVE HOPE THIS HELPS
Jan 19, 2011 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Which of Hitachi Hard discs could be a better replacement for model HTS541080G9SA00???
Just choose Hitachi Travelstar 320 GB, 5400 RPM, SATA , 2.5'' for convenience files storage.
Dec 19, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
My hard drive is not working-(hitachi HTS541616J9SA00 ATA DEVICE)
If it has failed then it is unlikely you can recover anything from the drive.
There is an old trick, remove the drive from the laptop, put it into a freezer bag and place it into the freezer compartment of your fridge for at least one hour. Remove it and insert back into the laptop and if it boots up then back up your data before it fails again.
If it doesn't work, there are data recovery companies that can recover data from failed hard drives but it will cost you an arm and a leg for their service.
You need a new hard drive to make your laptop reliable again.
May 02, 2009 | Compaq Computers & Internet
Installation
What ATA setting does your computer support? Hitachi makes a program you can drop the ATA settings down on your drive and that might fix your read error problems. It's called Feature Tools and it is on there website. http://www.hitachigst.com
Jan 13, 2008 | Hitachi Deskstar T7K500 320 GB ATA-133...
Hitachi HTS541612J9SA00 120 GB SATA Hard Drive Logo
105 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
