Question about LG Xenon GR500 Cell Phone
Mouth piece my mouth piece is on and off
Cannot hear my voice when somebody calls me
are you referring to a phone? If yes, it means the mouth piece (mic) of the phone is defective or maybe dust or an object is blocking the mouth piece hole.
You need to disassemble the phone and clean the mouth piece part. And if that doesn't help, replace the mouth piece.
Or you can use handsfree (earphone) with the phone pending the time you fix the mouth piece problem.
Regards.
Sep 20, 2011 | Cameras
My daughter has an lg c300 mobile phone when i try to ring her or anyone tries to ring her she can hear us but we cannot hear her. any solutions
hello
The mouth piece of the lg c300 phone is bad. It is the mouth piece that will enable you to hear from her.
You need to replace the mouth piece of the phone. Open the phone the with a screw driver, the mouth piece is located at the place were normally put her mouth when she talks on phone. Remove it, take to the store and my the exact type of mouth piece to replace with the old one.
Couple the phone and use it. i am sure it will work.
Note, before replacing the mouth piece, clean the pannel where the mouth piece is place with methylated spirit and allow it to dry. couple the phone and try if it works if the problem continues, then try the first method given above.
Thanks for your patronage
Jun 09, 2011 | Cell Phones
Caller cant hear me on my motorola cliq
The problem is that the mouth piece on your phone is malfunctioning that is why people call or people that calls you barely hear you.
All you need to do is to replace the mouth piece of your phone and you will see that after the replacement of the mouth piece, anybody that call you or people you call will hear you clearly.
Just change the mouth piece as advice and you will see that the problem is solve. meanwhile, you can be using hands free pending the time you will replace the mouth piece.
Feb 05, 2011 | Cell Phones
Iss having mouth piece problem
Hi, problemcan be solved,lets go straight to the point, you will need to replace the mouth piece with a new one. how to disassemble the phone. You can use the link below to see how it looks.
http://www.formymobile.co.uk/6300disassembly.php
You can use the fourth image to see where the mouth piece stays, Below the case you will see a round object that's the mouth piece,
Remove and go to any repair store around your area at purchase a new mouth piece, and your done.
Hope that helped.
Thanks for using fixya..
Jan 18, 2011 | Nokia 6300 Cellular Phone
I can hear callers,they cannot hear me even on full volume
when you call someone and they can't hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced.
When you replace the mouth piece, people can now hear you.
Take care.
Sep 03, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
When i ring people they cant hera me talking bu i can hear them
Hi
If a problem like this occur it means the mouth of the phone is faulty.
You can use a hands free to make calls until you have money to change the mouth piece.
To change the mouth piece piece open the the phone and bring out the mouth piece and the tale end of the phone were you normally put your mouth when making call. Replace The mouth piece with a new one and the problem is solved.
Regards.
Aug 28, 2010 | Cell Phones
I just bought Nokia E71 and when I talk to ppl they can bearly hear me even though the volume is up to max
Take care
Aug 20, 2010 | Cell Phones
Hello i have a new sciphone i9 I can hear the other person but they cannot hear me help. and when i do a voice recording, nothing is recorded
Take care
Aug 07, 2010 | Cell Phones
When i answer a call i cannot be heard
The problem with your phone is the mouth piece, the mouth piece of your phone is bad that is why you cannot be heard while you call.
I advice you replace the mouth piece by changing the mouth piece on your phone. replace the mouth piece and you will see that you will be heard after you replace it.
Meanwhile, you can be using your hands free while calling before you replace the mouth piece.
Take care.
Jul 05, 2010 | Samsung SGH-G600 Cellular Phone
I can hear my voice in the headphone, and the other caller cannot hear me
The fault should be from the mouth piece of your phone.
Use a phone screw driver to loose the phone, remove the mouth piece and clean the phone board, especially the mouth piece area of the board. Put the mouth piece back and make sure it contacts the phone board very well. Couple back the phone and test it.
If it still gives the same fault, the I think you need to change the mouth piece completely.
If you cannot get another mouth piece, then I would advice you get a hearphone to receive and make calls for the main time, till you get another mouth piece.
I wish you the best of luck.
Dec 28, 2009 | Nokia 6070 Cellular Phone
LG Xenon GR500 Cell Phone Logo
48 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
