Question about LG Washing Machines
My LG 7.2kg top loader makes a loud noise when washing and spinning
My LG toploader washing machine makes a loud noise when washing and during the spin cycle. what could be wrong?
SolutionGuy
  • 331 Answers
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
Posted on Aug 12, 2007
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
