Question about Sanyo Heating & Cooling
Does not respond to remote - Sanyo Heating & Cooling
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
LT-24DG42J
013/ 054/ 055/ 060/ 065/ 067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
Feb 23, 2013 | JVC Televison & Video
I need to know how to program remote
To program a new remote to the system; open door, turn ignition on, press and release valet switch one time then, press and hold valet switch. System will respond with a chirp. Now press lock button on remote. System will respond with a long chirp.Turn ignition off. Test system. Repeat for additional remotes.
Sep 28, 2012 | Dei 7641v Responder Remote 160xvl 7641
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
2way remote for Python 872 not working
Make sure that the responder is set for your car. this responder can work for multiple cars...The owners manual tells you how to check.
Dec 29, 2008 | 872 Responder LE Security Remote Start
Wii remote
if both remote stop responding then there is something wrong with the sensor bar. try it in a different place.
Jan 22, 2008 | Nintendo Wii Console
TV does not respond to remote
Sounds like the sensor on the television has gone bad, since it works for the VCR. Try a universal remote that you can program the TV and VCR codes into and try it out. If it works for the VCR and TV then you know it's the remote, if the TV still isn't responding then your TV sensor is toast.
Jan 03, 2008 | Zenith B27A11Z 27" TV
Heating & Cooling Logo
16 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
