Question about Mitsubishi MS12TN Air Conditioner
Mitsubishi aircons: Erratic error codes and gas loss
Mitsubishi aircon with the following erratic error codes; E57; E49: E36. They also seem to loose gas after a while, can't trace down any leaks with pressure test at 35 bar. Runs well after re gas, slowly looses efficiency and need re gassing.
SOURCE: MITSUBISHI ELECTRIC'S AIRCON REMOTE CONTROL ICON
lock out controllers
Posted on Oct 20, 2009
heatman101
  • 43501 Answers
SOURCE: How to program timer to turn Mitsubishi aircon on and off daily
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
heatman101
  • 43501 Answers
SOURCE: mitsubishi aircon, model MWK-07CV, when
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
heatman101
Posted on Sep 09, 2010
SOURCE: ERROR CODE E33 ON A MITSUBISHI FDC304HEN. The
The high speed fan not kicking with High head pressure.
Model Mitsu FDC304 HEN
Posted on Nov 01, 2010
hvac1960
  • 2133 Answers
SOURCE: Hi I have mitsubishi aircon with an E6 error code.
E-6 Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify.
Posted on Jan 01, 2011
How to solve problem on 4G93 GDI,lose power went aircon is running,if u turn off the aircon while driving can feel the go fast than before,what could be the problem
I don't think you HAVE a problem. The AC system puts a significant extra load on the engine, and a slight loss of performance is normal.
Aug 14, 2014 | 1998 Mitsubishi Galant
My pajero v6 3.5 usually when i turn the aircon on then i shift the gear to drive the rpm just drop and turn off the engine, but withou turning on the aircon the engine wont stop what seems to be the...
the engine doesn't like the extra stress of the air con unit being run _ there is no way of fixing this _ unless you get a full engine overhaul or a secondhand engine and installed _ the engine is old and the extra pressure on it with the aircon it just cant handle it
May 27, 2014 | 2000 Mitsubishi Montero
Error code e 9
E9 indicates Voltage error. Check the power.
Feb 01, 2014 | Midea Heating & Cooling
Idle goes up and down when aircon is on
This is pretty much normal as the AC engages and disengages. Though it should be subtle and not erratic. Is it causing your engine to stall? Does your AC work efficiently or is the air not real cold. It should output around 40 degrees. The compressor may be going out or it needs oil. When the AC turns on the car idle sensor should raise the idle so the AC does not drag the idle down too far. If you turn AC off and try pounding on the brake & turning the wheel violently at the same time (in park of course) if you still have an erratic idle it's not the compressor. It will probably be the IAC or a vacuum leak is suspect.
Jun 29, 2013 | 1995 Mitsubishi Lancer
1994 mitsubishi lancer aircon problem..is it possible to change the mitsubishi aircon motor to nissans aircon motor?
best talk to an a/con technican as there is a size/capacity requirement for compressors. While it may be feasable to fit another compressor it needs matching tx valve condensor and evaporator to work properly. He should be able to tell you if it will work or not
Jan 27, 2013 | Cars & Trucks
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
Aircon is not working properly if i speed up up 100kph.
The evaporator is freezing up. Check to make sure it's not low on freon.
Feb 27, 2009 | 1990 Mitsubishi Galant
Hitachi Aircon
According to the error codes for hitachi, there is no AO code. The codes on the code list are all numeral.
Jan 09, 2008 | Heating & Cooling
Ducted aircon error code
1. check cirkit board.
Nov 30, 2007 | Heating & Cooling
Mitsubishi MS12TN Air Conditioner Logo
24 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
