Question about Canon imageCLASS MF6560 All-In-One Printer
Mf4400 duplex jams - Canon imageCLASS MF6560 All-In-One Printer
Hp4200 duplexer paper jam
If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
Mar 14, 2015 | HP LaserJet 4200 Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
How can I print both side of the paper in canon MF4400
Chooseproperties from the Print dialog. Properties may be indicated as Advanced,depending on the application software. Now Click the Page Setup tab. In thePrinting Type section selects 'Duplex Printing'.
When a media type other than Plain Paper, Photo Paper plus Double Sided, orPostcard is selected in the Media Type menu, duplex printing cannot beperformed. Now state Staple Side and the steps are:
1. The printer analyzes the Orientation and Page Layout settings, andautomatically selects the best staple position.
2. Click the Staple Side drop-down arrow and select the setting. If you want tochange the setting, select another value from the list.
3. If necessary, click Specify Margin... and set the Margin width.
Finally when the setting is completed, click the OK button at the bottom of thewindow. You will be prompted, while printing, to remove the printed page andreload it in the ASF. Needy on the number of pages to print, you will need torepeat step 7 until all pages have printed.
May 07, 2011 | Office Equipment & Supplies
Hi, Hope you can help, A CP 6015 jams on dupex 2nd side on entrance to fuser,it looks like something to do with pressure roller release mechanisum as when released an actuator moves across fuser entrance,...
The document I was thinking of referred to fuser wrap jams. I did some quick checking of duplex jams though and this might give you some guidance to check for.
These errors refer to jams when repicking to print side 2.
Cause Solution The spring of the duplexing media-repickup-sensor lever is unhooked Check the spring and place it in the correct position. The duplexing media-repickup-sensor lever is damaged Replace the duplexing feed unit. Poor contact of the duplexing media-repickup-sensor connector Reconnect the connectors of the duplexing media-repickup sensor (J1945), intermediate (J1909, J1950) and the DC controller PCA (J4105). The duplexing media-repickup sensor is defective Check the duplexing media-repickup sensor by the sensor monitor mode. If the sensor is defective, replace the duplexing feed unit. Poor contact of the duplexing repickup-motor connector Reconnect the connectors of the duplexing repickup motor (J1771), intermediate (J1908, J1939, J1941) and the duplexing driver PCA (J4104). The duplexing repickup motor is defective Replace the duplexing feed unit.
Mar 10, 2011 | Office Equipment & Supplies
The duplexer in our HP printer appears to be jammed. where is it located?
As you face the printer, walk around to the left side. You will see the power switch. Above the power switch is the duplexer. It pulls out.
You said the duplexer is jammed, so you might not be able to pull it out.
Is the duplexer jammed or is there paper jammed in the duplexer?
Dec 03, 2010 | HP LaserJet M5025 MFP Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
Canon imageCLASS MF6560 All-In-One Printer Logo
old marine
old marine
