Question about Avery DesignPro 2000 for PC
Avery laser addressing labels l7160
I need foolproof calibrations for avery l7160 sheets (63.5mm x38.1mm)to enable each text label to start and finnish inside its label boundries. mine start outside the boundries even after changing the print calibration settings to +40 on the verticle setting
  • james graham Jun 19, 2008
    cannott down load program to use existing labels
  • 265 Answers
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Posted on Dec 18, 2007
  • Anonymous Dec 22, 2007
    I also forgot to mention that I will always print onto a blank piece of regular paper, then hold the paper behind my label and hold them up to the light, so that I can see what I need to do to make the addresses fit into the label borders without error. It is really frustrating when you print one page and it is right and the next seven pages have half the labels off the margins by 1/8" It is ALMOST right, but you still have to print many of them over again.
6ya staff
SOURCE:
Label printing
you'll need new drivers for vista...get them here
Mar 20, 2008 | HP Officejet 5610 All-In-One InkJet...
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
How to make address labels
Get the Avery plug in for word from the Avery web site. It makes things so easy if you do.
Aug 18, 2014 | Avery 5160/8160 compatible (100 White...
I have an Access file with 132 names with addresses. I want to print them on Avery labels. How can it be done?
Avery labels have an ID# that when entered into the Avery site will supply you with the page format for your Msoft Office software.
Dec 14, 2011 | Avery 5160/8160 compatible (100 White...
How to print labels w/ 1320c
Using Microsoft Word:
  • Click on "Tools"
  • Click on Letters and Mailings
  • Select Envelopes and Labels
  • Select Labels Tab
  • Select Options to select Label Size
  • Select Dot Matrix or Laser / Ink Jet
  • Select "OK" to Continue, you will be prompted to manual feed Label sheet
Please note the 4 digits that precede the label size are Avery Label Numbers
You could also use OpenOffice
Mar 01, 2011 | Dell 1320c Laser Printer
I'm trying to print the cd label on the label paper but it's offset and won't print in the right area. I calibrated the printer but it still won't work.
Some CD label software allow you to adjust the "overprint" by resizing the image you are printing. If your software doesn't allow you to size your image larger than the label (so it overlaps) try a different program. Look for a setting that allows it to over print. It's not an exact science...you just have to try to make the adjustments you need. There are also different CD/DVD label sheet types where the labels are setup on the sheet differently. maybe a different setup may work better. However, usually Avery is pretty good.
Jun 12, 2010 | Avery DesignPro Deluxe CD-ROM...
How do I Print Address Mailing Labels from Avery 300-Easy Peel White Mailing Labels, on Windows XP,CP?
You'll need the actual Avery code for this, or at least the correct measurements.
Open up Microsoft Word. Go to 'Tools' and find 'Letters and Mailings' in the list. Then off of that is 'Envelopes and Labels'. Click on that one and a box will pop up. If you click on 'Options'. From here you can find the correct label settings by the code which will be on the Avery pack. If you haven't got the code, you can scroll through the lists and highlight options to see the measurements but this will take you a while.
Once you chosen your labels, click on ok. Now you can enter your address in the box and print a whole page of the same address or click on 'New Document' and that will give you a page set out correctly for that label sheet.
Nov 19, 2008 | Computers & Internet
Printing labels
You have to feed the labels through the manual feeder.
Aug 23, 2008 | Brother HL 2140 Laser Printer
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
Open Questions:
See all Avery DesignPro 2000 for PC Questions
Avery DesignPro 2000 for PC Logo
1,283 people viewed this question
Top Avery Computers & Internet Experts
Donna Sander
NOEL
NOEL
Marvin
Marvin
Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
