Question about Toshiba Tv Lamp/bulb 23311168 D95-lma 62cm9ua 62cm9ue 72cm9ua Original Bulb
After replacing tv lamp
Hi there, I have a Toshiba TV(62CM9UA).The colors came into yellowish and dark a couple of days ego. I replaced the lamp by a new one.When turn on the TV ,After the 8th auto start the PICTURE IS STILL DARK, colors are not yellowish but not in original color yet.Also the menue list is no more at the center of screen.it became bigger size and located at a lower level on screen.I would be thankful if you could guide me to fix it. Thanks,
    Champion:
  • 213 Answers
Your dmd is bad
Posted on Nov 21, 2013
  • 2920 Answers
SOURCE: PICTURES HAVE COLOR BLURRY ON TOSHIBA 72HM196
you might try to adjust the focus
Posted on Dec 14, 2008
SOURCE: TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
Posted on May 15, 2009
  • 111 Answers
SOURCE: Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Posted on Feb 03, 2010
  • 30 Answers
SOURCE: projected colors separated
I am working on the exact same problem with the same symptoms. Make sure the tv is unplgged for at least 5 minutes before poking around. The power cord can be unplugged from the power board and removed to keep anyone from plugging it in while you are working on it.
The STK's are the large 18 pin integrated circuits (chips) mounted to the large heat sink on the convergence board. This is the board on the right when viewed from the back of the TV.
The resistors are beneath the heat sink on the left side of the board. There are also fusible resistors, like #7711, on that side. There are NO pico fuses in this area.
Fuse 853 is on the Power board. This is the board on the left when viewed from the back of the TV. You can remove both boards in the carrier by carefully unplugging all connectors, noting their locations and routing.
To remove the high voltage wires from the splitter, mark them for position then grasp the boot and turn counter-clockwise about 10 degrees to unlock them and then pull up while holding the High voltage splitter. The small high voltage wire can be removed from the flyback transformer by pulling hard while holding the flyback.
STK392-110 can be replaced with STK392-120, STK392-180, STK394-160.
I have found most of the parts at newark.com. Also check out this site for some very good info: http://www.hometheatershack.com/forums/diy-repair-maintenance/5600-crt-based-rptv-convergence-repairs.html
btw: I am not affiliated in any way.
Make sure that while you have the boards out you look for any bad solder connections. A lot of problems arise or return because of this.
I hope this helps, I have been doing a lot of searching to get this info and hope it helps you. Too many people want to trickle the info and pretend they are giving you gold. A few hobbyists or people that can't afford to pay $300+ for repairs are not going to hurt their business.
Be safe and share knowlege freely!
Posted on Mar 02, 2010
  • 336 Answers
SOURCE: replaced lamp in toshiba 46hm84. still get
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast is the most common failure besides the lamp.The ballast is the one that displays the lamp indicator if it's not able to power bulb or if bulb is not responding.Have a blessed one!
Posted on Mar 30, 2010
Is my color wheel need replaced?
the bearings of the color wheel could be worn. the screws hold it in place, & there is a plug-in wire connected to it.
for part# contact: http://support.toshiba.com/
Dec 02, 2014 | Toshiba 50HM66 52" Television
52WM48P Rear projection TV Lamp fitting
Original brand Toshiba lamp ,unit price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 13, 2014 | Lapbix Tv Lamp For Toshiba 52wm48p 120...
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
I have a Sony Grand Wega KF-60WE610 television. It now seems that the picture is darker than it used to be. I can still watch a show, but many people who have seen my television comment on the poor...
I'm sorry that the pictures on the TV screen is black. Based on the information you have provided, it appears that the issue is with the Lamp itself. The lamp of the TV may have to be replaced within two to three years depends upon the amount of usage.
If the screen becomes dark, the color looks unsual or the LAMP indicator on the front of the LCD projection TV flashes, it is time to replace the lamp.
Thanks for understanding. Please let me know if you require further assistance in replacing the lamp of the TV.
Jun 08, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tv stays on for couple of minutes and then shuts off
Hear any grinding or motor noises,pictures flashes or flickers in black and white?All these cause are the death of a colors wheel.Must replaced the colors wheel.When was the last time,this tv replaced it projection lamp?1 1/2 or 2 years the projection lamp was replaced,tv on and in used like 4 or 5 hours a day.The projection lamp life is over.Require a new projection lamp.
Aug 16, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
46" Rear Projection Hitachi - Green / Yellowish Screen
daveT29 - I had my brightness cranked, too. The picture went dark and off-color after moving the TV from one corner of the living room to another.
After waiting for the TV repairman for about 4 weeks, I "fixed" it myself. Take the front panel off (4 screws, then a black panel) and blow out all the dust. I was afraid to use a swiffer duster because of the static electricity, so i just used with my mouth blowing powers.
That's it. Seriously.
Jan 09, 2008 | Hitachi 46F500 46" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
I have a Toshiba DLP 62CM9UA
hello everyone, I have been in this field for many years and if you have any problems about projector lamps or your projector ,pls just inform me and i will try my best to solve these problems. I am now still engaged in original projector lamp modules/ original bare lamp/ original lamp with housing/ replacement lamp/compatible bare lamp/main board/liquuid crystal chips/color wheel and other related accessories for the most popular projector brands... if u want to buy projector lamp ,welcome to contact with me. tks&best regards Grace MSN:myth_grace@hotmail.com skype:myth_grace email:grace@awolamps.com
Dec 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Toshiba Tv Lamp/bulb 23311168 D95-lma 62cm9ua 62cm9ue 72cm9ua Original Bulb Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
