Home | Dacor | Epicure ERD36 Dual Fuel (Electric and Gas... | Dacor oven door does not...
Dacor Epicure ERD36 Dual Fuel  Kitchen Range
Problem for Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen...
Dacor oven door does not close completely
By rjhodder1 on May 05, 2009
This Dacor range works well. It is gas cooktop and electric convection oven. The issue here is that the oven door will not close completely. I can push it shut with little effort, but it does not stay shut. It is open, maybe, a half inch at the top. Food cooks fine in it. Seems like the springs are weak????
Anyone run into this problem before? What are the fixes?  Dacor oven door does not close completely. It is easy to push closed but comes back about 1". Seems to cook alright but is not right.
Solution #1
posted on May 05, 2009
Somewhat Helpful)
jumptrout51
Rank: Guru
Rating: 89%, 969 votes
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Was this helpful?
Yes
No
Popular Solutions for Dacor Epicure ERD36 Dual Fuel
Questions and Unsolved Problems for Dacor Epicure ERD36 Dual Fuel
Do you recommend Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range?
Answer
Answer
when i select bake to preheat oven the bake element does not glo on only the broil burner. then when... (More)
Answer
I have a similar problem with thr F1 warning alarm that goes off at all hours of the day and night.... (More)
Answer
We have had a problem with the control panel since we bought this unit. Dacor rep says to turn stove... (More)
Answer
Can you suggest a solution ? The guide indicates F1 means ""Element relay circuit...
Answer
This is a caravan oven and has been out of action for this summer period any help is gratefully... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dacor Epicure ERD36 Dual Fuel ...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
