Question about Panasonic Workio DP-4530 Copier
Error 01 carriage jam on avantra 44s what can i do?
The machine refuse to load media and continue to bring the error 01 carriage jam
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
MAYBE THE CARRIAGE IS FAULTY.DID U TRY A NEW ONE
Posted on Nov 19, 2013
Testimonial: "I have not try a new one before is any way i can solve the error 01 that it bringing most of the time?"
The Power light and the Resume light blink.
Print media is jammed in the
device.
Remove all media from the output
tray. Locate and clear the jam. For
more information, see Clear a jam
in the device.
The device carriage has stalled.
• Open the top cover and
remove any obstructions
(such as jammed media).
• Press (Resume button) to
continue printing.
• If the error persists, turn the
device off, and then on again
Feb 10, 2014 | HP Officejet 7000 Wide Format Printer
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
System error 86:01
System Error 86:01, Noise Along the Carriage Path carriage moves or system error 86:01 is being displayed on the printer's front panel. General causes are media or other obstructions in the carriage path, the trailing cable, worn carriage bushings, lack of lubrication in the carriage path, a dirty encoder strip, the scan-axis motor, or the service station.
Troubleshooting this error is a bit complex, you have to check for paper jams and determine the source of the noise, if there is one.
Try checking this document for steps to determine the cause and solution to this issue.
HP Designjet 500 and 800 Series Printers TWI System Error 86 01 Noise...
Aug 08, 2013 | HP DesignJet 500 InkJet Printer
Agfa avantra 44s error no 185 how to solve this problems
If you wish to get some details; check the site linked here. Pull up older posts..
http://electro-medical.blogspot.com/
Oct 03, 2010 | Office Equipment & Supplies
HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
ERROR 86:01
General causes are media or other obstructions in the carriage path, the trailing cable, worn carriage bushings, lack of lubrication in the carriage path, a dirty encoder strip, the scan-axis motor, or the service station. Follow the steps listed below to accurately troubleshoot the issue, and replace the appropriate parts.
1. Visually check for jammed media or other obstructions in the carriage path and remove any obstructions found (remove any loaded media as well).
2. Determine if the noise is normal. Some noise is normal. Specifically, it is normal to hear a slight clicking noise when the carriage moves under the left or the right-hand covers.
3. If an 86:01 error occurs during initialization and the carriage does not move out of the Service Station continue Step 4, otherwise go to Step 5.
4. Remove the right cover and check the cable connection between the Interconnect PCA and the Service Station motor. If connections appear normal, replace the Service Station
5. Attempt to verify functionality, if problems persist, continue with the remaining steps.
6. Unlock the carriage as instructed below:
a. Highlight the Set-Up menu and press the Enter key.
b. Press the Up Arrow and Enter keys simultaneously and then press Enter.
c. Scroll to Service Utilities and then press Enter.
d. Scroll to Unlock Carriage and press Enter.
e. Unplug the printer from the power source.
7. Move the carriage manually through the entire movement path to see if it encounters any obstructions or has more resistance in any particular spot. Remove any such obstructions if possible.
8. Clean and lubricate the carriage rail.
9. Slide the carriage manually back and forth several times to evenly spread the lubrication across the entire carriage rail.
10. Turn the printer on and attempt to verify functionality.
Nov 13, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
I keep getting a problem error 86:01
If you don't see a paper jam it's a carriage axis error. Try cleaning and then lubricating the bar well. Next look at the belt turn around on the non-motor end of the belt. You'll find a bearing in the spring loaded pully that wears out or ceases up. If the drag / friction is too high you will get the 86.01 error. I have included a link to a free copy of the HP Service Manual to help you get through it. The error is discussed on page 2-18 and 2-19.
Hope that helps you.
Feb 19, 2009 | HP DesignJet 500ps InkJet Printer
Panasonic Workio DP-4530 Copier Logo
89 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
