Question about Epson AcuLaser C900 Printer
Epson C900 print shifted down page -
I used to print out from MS Image composer on A4 size paper setting. Previously, the C900 did not complain and printing was ok. Only recently after leaving 1.5 inches blank from the top A4 paper, it starts to print the images and the rest falls off the end of the page and it tells me that incorrect paper size has been used. I have not changed anything software driver or hardware, which leaves me puzzled. I have tried changing paper size , offset setting it does not help much as in felix case. I am using XP. I have reinstalled the drvier on another laptop and it has the same behaviour and error. Please advise and thanks in advance.
  • 3 more comments
  • Alexthecrate Dec 22, 2007
    Hi der
    Interesting problem. I have the same problem and have no idea what is wrong. I have chased all though the settings trying everything but no joy.
  • Boddger Feb 22, 2008
    Recently installed MS XP. Print starts 35mm down A4 and the rest drops off bottom of page.
  • tungoon Mar 19, 2008
    I sort of have to same problem although not with MS image composer. The printer I installed hasn't been used for about a year and a half, but before there was no problems, but when I install it now the printer test page is shifted down almost 10cm. I have tried just about every combination of settings there is with no luck. However when I change the settings to print black instead of color the page is only shifted about 5cm down. Printing in black got rid of the incorrect paper size message for the test page, but when I tried to print a document with 2 pages from Word the first page came out with the 5cm offset and the second page came out with 14cm offset and the incorrect paper size message came once more.
    Has a solution for this problem been posted somewhere?
  • Anonymous Jul 16, 2008
    the same prpblem. it always left blank at the top of the paper.
  • tselyc Nov 16, 2008
    I've exactly the same problem. Paper jam almost everytime print the first page and sometime it can print but every page shifted down about 10cm. Anyway to repair it? Warranty has expired, worth to call maintenance?
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Posted on Dec 22, 2007
    Problem Solver:
  • 14 Answers
Hi chara
chara i have delayed to respond to your question because i wanted to simulate your situation. To say the least i have setup my machines to the dimensions you have mentioned but i still get good prints with obviously that final message that "incorrect paper size"
pass more details on 1. ms image version 2. printer settings (reset all to default) 3. ms image printer properties settings.
i have a feeling that this problem come from ms image end
Posted on Dec 20, 2007
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
When printing uisng an mf4270 I get an error "load correct paper". I am using A4 and the setting is A4 on both printer setting as well as printing driver. My OS is Win7 and editing software MS office and...
Hi
Just a thought but is the printer detecting the "type" of paper you are trying to use, as opposed to simply the size. For example, is it trying to load "glossy photo paper" specified by the printer utility and finding standard photocopy paper.
Cheers
Dec 06, 2014 | Canon Image Class MF4270 Monochrome Laser...
I could not print from ms word 2007
Have you been able to print previously or have you recently installed a new printer?
In word, check the paper settings are the same as your printers, ie A4 or an imperial size. If Word wants to print to A4 and your printer has no tray containing A4 then it won't run the print job.
Is there paper in the tray of the printer?
Can you print a test page from the printer menu itself to ensure that the printer is working okay.
Apr 21, 2011 | Microsoft Office Professional 2007 Full...
The printing goes off the page
pls set the paper size to the actual paper size you load.. you have probably selected legal size in your pc and load an A4 size paper onto the printer...
May 26, 2010 | Epson LQ 300+ Matrix Printer
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
Epson dotmatrix printerseting i want the page set har bar page set karna parta ha
Jaisa ki aapne kaha, har bar page set karna padta hain.. Here's a solution.
sabse pahele aap aapke windows printer and faxes folder main jaayeeye wahan par aapka jo bhe dot matrix printer hain usko right click kijiye. Uske baad Properties main jaakar printer ke liye hamesha jo paper use hota hain say, A4, FS, A4 Continuous stationary etc. select kar ke save kar lijiye.
Aab aapke document main jaakar jo paper size aapne printer par set kiya hain uske aanusaar page size select karke print le lijiye.
Aab ki baar saahi print aayegi.
Feb 17, 2009 | Epson LX-300 Matrix Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Do i can customize my paper size in MS Excel 2003
When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
Dec 18, 2008 | Epson FX 1170 Matrix Printer
Epson Stylus Photo R260 doesn't complete prints
Make sure that you have the correct paper size set in your printer settings. Incorrect size would cause the problem you describe.
Sep 17, 2008 | Epson Stylus Photo R260 InkJet Printer
Will not print 4 x 6 prints
try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Sep 25, 2006 | Canon S520 InkJet Photo Printer
Epson AcuLaser C900 Printer Logo
1,107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
