Question about Pool & Spa
Paramount chlorinator cl 110 - Pool & Spa
CL-200 lid won't lock into place because it's to tight.
Gasket in lid is swollen from chlorine gas over time, check to see if you can tuck back in and lubricate it with a silicone grease. if to swollen, replace gasket.
Jul 05, 2011 | Hayward In Line Chlorinator 9 Lb. Capacity...
After bonding atoms we are ask to name the resulting compounds in its common name and as well as its chemical name. so my question is, what is the difference between common names and chemical names? please...
Common name is the name what people call it, it usually gives you no idea as to what the chemical composition of the compound is. (eg: Common name for Sodium Chloride is Salt) whereas the chemical name is based on what the compound is made up of (A molecule of salt is made up of one atom of Sodium and one atom of chlorine. this can be understood from the chemical name, but not from the common name.)
Mar 08, 2011 | Computers & Internet
How can i tell if the chlorinator is working on my intex pump. i pluged it in inputed hours to run and working led is on but i dont hear any noise from the pump it self. no low,high salt indicator. no...
Turn up the setting ... if the CL is reading 0 then you aren't making any CL. Your salt is at 3400 ppm? And you determined this how? Does your generator test for salt content?
If you are using your pool, I suggest you start by introducing some powered CL to get the level to 2 to 4 PPM while you monitor the operation of your generator.
Aug 25, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
Pool water is green. The free chlorine strip shows zero. What do i do?
You have copper in your water ... the CL bound immediately with the copper and iron to make your water green. Get a sequestering agent and apply according to the container instructions (the lower the CL, the better). Run your filter 24 hours for several days to clear the metal out. Back wash the filter then introduce CL to 5 ppm
Jul 20, 2010 | Intex Automatic Salt Water System for ...
What chlorine should i use for my pool?
You should use granulated CL in this pool. Maintain CL at 5 ppm - check daily.
Jul 20, 2010 | Intex 15' X 42" Easy Set Pool Complete...
Is a Hayward cl-100 ef chlorinator the right model to use for a 27 foot round above-ground swimming pool. I am having trouble keeping the chlorine level at an adequate level (dips too low) even with the...
The cl100 should do the job. The first thing I would do is check the chemicals. Make sure you have enough stabilizer (cyanuric acid).If it's low your chlorine will not last long at all. Check the ph and alkalinity also. Make sure you are running the pump long enough. the cl100 only adds chlorine when it's running.
Jun 05, 2010 | Hayward Pool Products 25 Sq Ft Micro Clear...
12500 gal pool began by adding 8 \ 40# bags of
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
