Defy electrologic 1300 makes a noise when spinning
3 Suggested Answers
  • 6277 Answers
SOURCE: my electrologic 1300 m will
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
SOURCE: I have a defy electrologic
My laundromaid washing machine is not cutting water after filling please help
Posted on May 20, 2012
I have a Defy electrologic laundromaid 1300 washing machine that the cold water runs in even when the machine is switched off.
Your solenoid operated valve is stuck open on the cold side. To find this valve, follow the cold water inlet hose and it will lead you directly to it.
Feb 01, 2017 | Washing Machines
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
