Question about Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od
Key wont turn in the ignition feels like wrong key
    New Friend:
  • 5 Answers
I've had Toyotas, Hondas, BMW's all do the same thing. It's the same key, but at the odd time, it won't turn.
#1 Cause and Fix
There is a security locking mechanism with most key ignitions. Even if the key slips into the slot, the pressure from the angle of the tires turns the steering wheel ever so slightly putting pressure on the key slot mechanism. Frequently, something as simple as you jiggling the steering wheel will relieve the pressure and allow the key to turn in the ignition.
#2 Some cars require the gear shift be in park in order to turn the key and start the car. They have safety mechanisms that prevent a dangerous situation.
#3 Some cars have a safety mechanism that won't allow you to turn the key unless both the shifter is in park and your foot is pressed firmly on the brake.
#4 Sometimes dirt, water/ice can get into the key mechanism (especially true of outside door key locks). In this situation you might need a locksmith. There are some steps you can attempt. First, remove any visible debri. Any auto parts supply shop should have other items to help. There are graphite key slot lubricants, there are aerosol cans of high pressure air for cleaning key boards/electrical components (and possibly key slots) or even WD-40 for getting sticky locking mechanisms to free up. It depends on your situation and the age of the car.
#5 This is the worst case where the key mechanism is damaged by someone forcing a foreign object or materials in the key slot. In this case, you will likley need the ignition entirely replaced. Sometimes, something as simple pulling a key out of the ignition slot quickly at an improper angle can damages the key slot cover plate. In this case you may be in luck. With the right tools, needle nose plyers, a flat head screw driver and a lot of patience, you may be able to straighten or fix a bent slot cover plate that will allow the right key to fit into the ignition and turn.
Good Luck
Posted on Nov 19, 2013
  • Tommy Thomas
    Tommy Thomas Aug 01, 2014
    try putting oil on key and insert key and wiggle it...it works some times
  • 430 Answers
I find both answers helpful...but must add on my 91 Honda a while back I had to have a new key made....Keys wear out quick if you have a bad ignition switch....but at $2 a key for the honda I had 3 made and it worked untill I sold the car :)
Posted on Aug 13, 2016
    Sergeant:
    Habit-Forming:
  • 116 Answers
Steering wheel lock automatically, almost most of the cars have this feature, the main purpose of this feature is to prevent theft. When the vehicle is turned off, the steering wheel placed at an angle, it will trigger automatically locked, if this time the keys in the ignition is screw fixed. Automatic steering wheel lock solution is very simple, put the key into the keyhole, turning the steering wheel left hand around his right hand twist the key, until the key can twist, unlock the steering wheel.
Hope it helpful!
Car Diagnostic Tool
I accidently put another key in my ignition of my 2001hyundai accent and now my key won't start the car
Do you mean that after you removed the wrong key your original key wont go in, or do you mean using your original key and turning the starter it wont start or even turn the ignition on. If you tried to turn the ignition switch with the wrong key, sometime it will cause the lock to turn freely as an anti theft measure. You should be able to find the way to fix this in the user manual that comes with the car.
Dec 08, 2017 | Cars & Trucks
Ignition key turns loosely approximately 1/4 of the way but won't advance to start. Steering wheel feels,locked
possibly bad tumbler might change ignition, heavy key rings are responsible for a lot or ignition problems, lighten up your key rings
Jan 08, 2016 | 2003 Jaguar Xkr
Something wrong with my ignition what could be wrong
sounds like the ignition key switch is worn and needs replacing.
Sep 07, 2014 | 1997 Mitsubishi Galant
Wont go into gear or ignition wont turn.
did you try wigglin the wheel to get your key out sounds like you need a new ignition switch.
Apr 25, 2010 | 1999 GMC Sonoma
Will inserting the wrong key in the ignition of a 2003 focus screew up the PATS? I replaced the key cylinder that had locked up. I inserted the wrong key (non PATS) The one for the doors. It turned the...
inserting the wrong key wont damage the pats its just a no start condition.using a non pats key wont solve the problem either.when using unprogramed key the pcm will disable the ignition system and the starter
Jan 14, 2010 | 2000 Ford Focus
1999 CAMRY KEY WONT TURN
Change the ignition barrell.
May 30, 2009 | 1999 Toyota Camry
Key won't turn the ignition switch in 1999 Saturn SL1
Turn your steering wheel to allow the ignition to fully unlock while turning the key.
Feb 08, 2009 | 1999 Saturn SL
Locked ignition and steering column
either you have the wrong key,or try turning the steering wheel to the right all the way,then turn key,this usually happens when you park the vehicle and the wheels are turned,then the steering wheel locks hard
Nov 01, 2008 | 1985 Dodge Ramcharger
Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od Logo
125 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
baire
jim
Level 1 Expert
mekanik84
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
