Question about HP ScanJet 8270 Flatbed Scanner
How to hard reset hp scan jet 8270 error 06 - HP ScanJet 8270 Flatbed Scanner
3 Suggested Answers
SOURCE: HP 8270 does not scan on windows Vista . Could not
I cannot find the documents that I scan, and if I have the scanner preview the document it shows the document but then it will not save anywhere. I have tried deleting and reinstalling the latest driver but without any change in the problem HP Scanjet 8250 and this started without warning. I have had the scanner for a year and it worked with out any problems then poof no more scanning.
Posted on Feb 11, 2010
  • 114 Answers
SOURCE: What is an error 06
The bulb needs replacing. Check this: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=c00022537 for errors .
Posted on Mar 23, 2011
When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
Tip
Windows 7 and HP scanjet 8250, 8200, 8270; front panel buttons and searchable...
How to install a HP scanjet 8250 in windows 7 with full features like double side scans and searchable PDF creator.
The basic driver automatically installs with windows 7.
The basic driver lets you scan one page at a time and does not let you do advanced options like double side and creating searchable PDF's.
HP has a software package listed for the HP 8270 scanjet that works properly with the 8250 scanner. I would assume that any scanner in the 8200 series would work with this software.
For full scanning features, I installed the HP photoshop essentials and the HP solution center. Find the download here, on HP's web site.... http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1118286&prodTypeId=15179&prodSeriesId=1118292&swLang=8&taskId=135&swEnvOID=4062
Click on the software link .."HP scanjet Full Feature Software and Driver"
After the install run the setup and follow the directions,
After the install, the front panel buttons on the scanner should now work. You should also be able to create PDF's(searchable) with the one touch of the scanner button.
on Jan 28, 2010 | Computers & Internet
HP 8270 does not scan on windows Vista . Could not complete scan is the error message
Make sure you have the newest vista drivers located here - also, make sure that the scanner platen is travelling the full length of the scanner, it's not being hung up somewhere causing it to jam. Try to scan while the cover is open to watch the scanner head travel.
Oct 21, 2009 | HP ScanJet 8270 Flatbed Scanner
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
Automatic Cropping...
Before turning off the autocrop feature, reset the software to the default setting. Then turn off the autocrop feature. Some scanning software need to be reset to the original default condition and accept software switches only then!
S. Mohan
Dec 05, 2007 | HP ScanJet 8270 Flatbed Scanner
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
HP ScanJet 8270 Flatbed Scanner Logo
168 people viewed this question
Seeker5211
Seeker5211
