Question about Microwave Ovens
Defrost instructions for mistral essential microwave
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
How to defrost in belling microwave oven del stw25 ?
Visit the companies web site and download the manual.
Sep 16, 2014 | Belling Microwave Ovens
Mistral microwave MUMW23SS has no heat, light comes on, turntable operates OK, tested the megatron and reading 0.4 ohms, tested the internal fuse this is OK any suggestions
The keypad control board is more than likely the problem, if microwave is less than 7 years old the inverter board has been a source of trouble from time to time. When you consider parts cost it will approach if not exceed the value of a new microwave oven.
Apr 07, 2012 | Microwave Ovens
Hello I need a manual for a mistral living essentials microwave model no. LEMW23SS
Very sorry, but I've been looking for your manual without getting any. on line.
Sep 03, 2011 | Microwave Ovens
How to defrost frozen ground beef with sharp carrossel microvawe oven?
The defrost instructions for ground beef are listed on page 15 of the owner's manual under the "Defrost Center" heading. If you do not have an owner's manual, here is a direct link to one that you can download or print for FREE:
http://www.managemylife.com/mmh/owner_manuals/71305/Sharp-Microwave-Oven-mic_man_R510H?brand_name_search=R-510
Remember to remove any thawed pieces of beef with each stage of defrosting for the best results. If you have any questions, please post back and let me know. I hope this helps you.
May 05, 2011 | Sharp R-510HW Microwave Oven
Operating Instructions Mistral MMW17SS
Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
Here are the steps:
1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
your frustrations are over my friend!
May 07, 2009 | Microwave Ovens
How to defrost
Can only suggest trial and error to "Start it".
Since it belonged to ***********, would she know?
Alternatively, use the lowest possible power setting instead of the defrost function but take care not to "Over defrost" if using this method.
Feb 18, 2009 | Microwave Ovens
Microwave instructions onn OM007
Sorry, I have searched through all my resources, but I cannot find a manual online for your microwave.
Sep 29, 2008 | Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
