Question about Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od
Key not turning in ignition vr calais 1993 - Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od
    Problem Solver:
  • 5 Answers
Have you tried turning the steering wheel in either direction as you turn the key?
Posted on Nov 20, 2013
How to fix VR Commodore ignition switch?
Please go to JustCommodores and the guys will help you out with that. Here is the Forum link.......
Forum VR VS Holden Commodore 1993 1997
Aug 22, 2016 | Cars & Trucks
How to find the build number on my 1993 holden calais international,
VIN# are in the on the dash, drivers side, at the bottom of the windshield. They are also on the drivers door or door frame. 17 digits long.
Jul 10, 2016 | Holden Cars & Trucks
Key won't turn and steering is lock on a 1990 Oldsmobile Calais?
Try to wiggle the steering wheel as you turn the key, the wheel may have some force on the lock so turn wheel to the right and try to turn key then turn left and try the key again. if this doesnt work then the ignition is worn and you will need to wiggle the key to get it to start also try to spary a little wd40 in the ignition key hole and work the key inside the ignition.
Dec 19, 2010 | 1990 Oldsmobile Cutlass Calais
Car wont start turn key nothing
could be dead battery, bad ignition, or a starter relay
Apr 06, 2010 | 1991 Oldsmobile Cutlass Calais
How to change the ignition on a 1993 ford
if you look on column right under switch you will see a small hole, theres the lock pin for the ignition, put key in ignition then with a small nail or pick stick in the hole push in then turn key slow you should feel pick push in the pin continue truning switch until a the dash lights come on and keep pushing in, then pull swith out, take new switch and turn key to same point as old slide in and turn key off, your done hope this helped.
Dec 20, 2009 | 1993 Ford Econoline
Ignition/starter failing to engage for multiple turns of key
sounds like the starter has a flat spot on the solenoid. remove and test the starter, replace if necessary.
Nov 06, 2009 | 1993 Volkswagen Fox
Describe your 1991 Oldsmobile Calais .When I turn the car off with the headlights on the car keeps running. When I turn the headlights off the motor turns off. ALso the tail lights and instrument lights...
It's not the ignition switch. Someone has been playing with the wiring. What was done to your car? Did someone wire up something to work that didn't or did someone install something that had to be wired like a stereo? Somewhere the parking light circuit has been wired to the ignition 1 circuit.
Sep 03, 2009 | 1991 Oldsmobile Cutlass Calais
Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od Logo
44 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
mekanik84
 Robert
Robert
Level 1 Expert
xkikbxr
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
