Question about Microwave Ovens
Speed queen noise when on spin - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Posted on Nov 19, 2013
What is the loud noise?
What kind of noise? Is it high speed fan? or rotating motor? Please describe!
May 02, 2014 | General Electric Ge SCB2000F 950 Watts...
Have a nexstyle mod 6540SA005STS SOLD AT COSTCO IS THERE ANY FIX TO OUIET THIS THING DOWN MAKES LITTLE DIFFERENCE TO FAN SPEED FROM LOW TO HIGH THANKS DOUG
Depending on what is making the noise, there are plenty of *computer* noise dampening kits out there which you might try applying to the fans screw terminals and anything els that might vibrate or make noise.
Mar 12, 2011 | Microwave Ovens
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
Where can I buy replacement handles for Amway Queen cookware?
Hi Maggie...
You can purchase replacement handles on amazon/ebay/aliepres etc... but personally I prefer amazon (fast and secure shipping, with affordable prices). So click here Amazon com cookware handles and pick one (which fits to your Amway Queen cookware). Anyway before order, contact the seller to be sure.
I hope it was helpful
enjoy
Dec 22, 2010 | Microwave Ovens
Kenmore washer
Top loader? The basket at rest is slightly to the rear. Slow spin speed could be the brake hanging up or a worn clutch. If these are ok the spin tube bearings may be tightening up. Eric
Dec 04, 2009 | Microwave Ovens
My plate does not always spin, microwave seems to be working when plate spins otherwise it just make noise but doesn't heat up. When I move plate manually it sometimes help, so I replaced electric motor...
The heating issue is related to the high voltage fuse and the magnatron assembly as well as checking the high voltage cao and the protective diode if the unit has one. As for the spinning dish u neeed to make sure the voltage of the new motor is the same as the old one. otherwise u may have issues with the motor not being able to spin efficiently. Good luck.
Nov 15, 2009 | Microwave Ovens
Lights up counts down and thats it no fan no spin no heating
I believe that there are to fuses inside this unit. One feeds the electronic components and the other feeds the turntable and the magnitron. Un plug the unit and check both fuses, you might get away with this cheaply. Please let me know if this helps. P.S. if one of the fuses continues to blow its time to get rid of the unit, because if they go bad they get stronger and very dangerous. What normally would boil water at 3 minutes could change to 45 seconds. Be careful.
Aug 13, 2009 | Zanussi ZM24ST Microwave Oven
Load Noise
Can you describe the noise?
Is it like a 60Hz hum?
Does it have a hollow quality to it?
Mar 14, 2008 | GE JES738 Microwave Oven
GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
99 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
