Question about Sony Xplod XM-554ZR Car Audio Amplifier
Dual xia2460 protect light on
Protect light comes on when turned on. subs are good and also ground . stereo works with another amp
blueextc3221
  • 15935 Answers
SOURCE: car amp has power but will not push subs
output blown on power supply - repair by tech required.
Posted on Jan 12, 2009
  • 18 Answers
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Posted on May 27, 2009
etirbynnor
  • 655 Answers
SOURCE: amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Posted on Jul 29, 2009
  • 31 Answers
SOURCE: the overcurrent light on my sony xplod amp
Contact eric @ Capital Audio & Electronics Repair in Tallahassee,Fl 850-339-1130 we repair all namebrands & models
Posted on Mar 20, 2010
SOURCE: My amp has power but then immediately goes red into protect mode.
Ok, being an old-school "back yard" installer when i began, gave me 2 immediate possible diagnosis for your problem. I was running a Kicker zx550.3 amp to 2 Polk DB 12'inch Subs rated 600w max 1500w. I also used a LOC converter (Line Output Converter) in order to use my stock Bose stereo since it did not have RCA outputs. Now shortly after running this setup (approx 2 weeks) I noticed a substantial drop in sound output and also noticed some ground noise/distortion coming thru the subs. After tracing my wires that connected my LOC to the Amp, and Rear Speaker Wires of my Radio to the LOC, I noticed that by jostling the wires there was a connection issue. If you are using your factory radio to power your regular component speakers (tweeters, coax, mids) then chances are your stereo feeds into a FACTORY INSTALLED amplifier. If thats the case, then you need to access a Wiring Diagram for the Harness coming off the Factory Amplifier! Once this is viewable, check the wiring and locate the "Amplifier to Radio Signal Wires" and also the "Amplifier to Speakers Signal Wires" ... Now go back to your LOC and look at the wires you tapped to get the Line Signals to the converter, and make sure that you havent tapped your lines off of the AMPLIFIER TO SPEAKER wires. These wires carry a small electrical current because they are coming powered from the Amplifier, and most Line Output Converters are PASSIVE, which could short the signal the LOC creates thus reducing your signal gain, but does have the capability to surge back to the Factory Amplifier, which could possibly melt the shielding of the factory wiring, and thus allow your signal to cross or ground out! If you can, try running another RCA input to your Sub-Amplifier from another source other than your car, and see if your protection lights go out and the amp returns to normal operation. If so then your LOC or Factory amp is to blame. If not, then the second diagnosis is much simpler, which is your Alternator current has been reduced due to many different possibilities, and you should acquire a .5 or 1 Farad Stiffening Capacitor which will reduce the excess draw from your charging system. But due to the first solution being my problem exactly, im willing to bet your's lies along the same variables... GL to you!
Posted on Apr 24, 2010
I have my amp hooked up right to two 12 inch subs but the red protect light comes on wht does this mean?
Check all your cable work.
Power is connected tight? Ground is attached tight - on both ends (my guess is it is the ground) Remote cable?
Is the ground a proper ground?
Mar 01, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Protection light comes on , was only coming on when i turned up the stereo , now it stays on , all the wires are good and i cracked the amp open and nothing looks burnt
check your gain on your amp. If it gets hot the shuts off into protection mode you are over working your amp. Check to see the way your subs are wired up and see if your amp can handel the load.
May 20, 2010 | Crunch Drive V-3004 Car Audio Amplifier
Red Power Protector light
Hi, the only way i can see the amp resets the stereo is that power is dropping. The amp should have its own wires directly to power/battery so as to not affect anything else.
On the protect, try to disconnet all the speakers, make sure the power is OK. If it appears to work, the there could be a problem with speakers/cables. Try a different speaker to see if it works. If the problem continues with speakers off, a different speaker etc, then there is a problem with the amp. Hope that helps
Jul 21, 2009 | Sony XM-2100GTX Car Audio Amplifier
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
When powered on protection light comes on
ya i would say its not grounded right
Mar 02, 2009 | Car Audio & Video
Directed audio 800a amp the protection light keeps blinking
1. Check your grounds. (including grounds for your stereo)
2. Check to make sure the power cable you connected to your car battery is properly connected, and not coming into contact with anything metal.
3. Make sure you are using proper fuses.
4. Check your connection from your stereo to your amp, and your amp to your subs.
Jul 18, 2008 | Earthquake Sound XTREME 900W.5 Car Audio...
Protection light stays on no output
i have the same amp and have that same issue before. yes you are correct that if you take off the RCA cables on the input there will be no light. either you have plug the remote line on the 12v or a grounded sub. it should be 12v/remote/ground from the corner. good thing im just fixing my sub earlier. it is no problem if you have hooked the remote line on the 12v, it is the same supposed to be. to check if your amp is working, short the 12v/ and the remote line and play your stereo and see if your sub is working. by the way, what sub are you using? i just blew my sub and need a new one.
Feb 02, 2008 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
No power
Disconnect the sub or speakers and turn on the amp, see what happens. If the amp turn on without the protection light, then your sub is blown. Also check to make sure ALL your fuses are good including the one under the hood. If you have a meter, test the fuse for continuity. The problem can also be a bad ground.
Aug 19, 2007 | Kicker KX150.2 Car Audio Amplifier
Amp won't put out sound
Hello, if you leave me your email I can send you the user manual for this amp. Best regards, Arpi
Apr 10, 2007 | Sony XM-SD22X Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
