Sharp gq 72
How to load the paper roll
3 Suggested Answers
  • 9 Answers
SOURCE: how to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Posted on Dec 30, 2007
  • 300 Answers
SOURCE: Hello, I have a problem with
You mean the Transaction Report ?
You can download the PDF format manual here and here.
Posted on Jun 20, 2011
When I try to make a copy in My fax sharp ux-108 the paper goes out blank
First make sure the original document is loaded with the correct side facing down. If not the problem try taking out the roll paper and reload it with the other side of the paper facing up
Jan 23, 2012 | Sharp UX 108 Roll paper Thermal Fax
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Want to know how to load thermal paper on my sharp Fax model FO-71
    1 - Grasp the finger hold and pull up to open the operation panel.
    2 - Flip up the front paper guide.
    3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
    4 - Unwrap the roll of thermal paper and insert the paper shaft.
    5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
    • Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
    come out blank after printing.)
    6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
    7 - Make sure the paper comes out straight, and then flip down the paper guide.
    8 - Close the operation panel, making sure it clicks into place.
    • FO-71: A short length of the paper will be cut off.
    Dec 01, 2010 | Office Equipment & Supplies
    Replacement paper roll size???
    Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
    Sep 26, 2009 | Sharp EL-1197PIII Calculator
    Cannot load new paper roll into the calculator so it catches
    Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
    When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
    To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
    Then, slide the paper roll onto the feeder arm and you're in business.
    Apr 09, 2009 | Sharp EL-1801C Calculator
    How to load paper
    Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
    Paper Loading
    Cut a diagonal to make a sharp corner on the end of the roll, then stick the corner into the paper slot, and then press the feed button.(arrow on top left)
    Oct 18, 2007 | Canon P23-DHIII Calculator
    50 people viewed this question
    jasbo
    jasbo
