Question about Xerox FX DocuCentre-II C3000 PCL 6
How to set up Iphone app to print using FX DocuCentre-II C3000 PCL 6
    Champion:
  • 411 Answers
You must have a wireless PC with iTunes + Airprint loaded - to provide a "shared printer" for IPhone.
Posted on Dec 21, 2013
E007-9901. already change new fixing but the same error code keep appear.. help me :(
what driver does it use ? can you print a configuration page from the device and compare the printer languages used. Example PCL 6 , PS . Is the driver matching the accepted languages the printer requires.
Jan 02, 2015 | Canon iRC4580i
DocuCentre-II C3000 win 8.1 Troubleshooter
From Windows 7, all firms who have a certification, to let their hardware run under Windows, get their drivers on Microsoft. They don't need to deliver the drivers to the costumers. If the driver is not in Windows 8.x, the firm will not have any certification. So trying to install an old driver, will not work. The driver does not have correct entries to the bios nor to windows. And although the website is recommending to download the XP drivers, they don't give any warranty they will work.
Try to contact your dealer or service centre, so they can solve the problem.
My guess? The advice you to go back to a stand alone PC with Windows XP.
Jun 15, 2014 | Xerox FX DocuCentre-II C3000 PCL 6
How to set up Iphone app to print using C3000
you need an airprint enabled printer, here is the official list: http://support.apple.com/kb/ht4356
is it an app you are using already? if not, try print n share, this will work even to a non airprint printer
Nov 19, 2013 | Xerox FX DocuCentre-II C3000 PCL 6
Can you tell me what error code 124-315 means on Xerox Docucentre-II 2055 ? and what the recommended fix is. (Multifuncton printer). Thanks, Gajj
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Jul 24, 2010 | Office Equipment & Supplies
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
Any Windows 7 64bit driver for Xerox Docuprint P8ex? The one posted by Droidd is probably 32 bit and does not work in Windows 7 x64. Thanks.
Hi, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
May 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
Windows 7 does not have drivers for Xerox Docuprint P8ex
Hi all, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
Feb 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Hp2420 does not print correct ranges in all apps.
I have found the solution. Quite simple. In the printers properties box select the general tab. Click on the on the printing preferences button. Selecting the Paper/Quality tab, observe the Print Task quick sets. These all need to have Default print settings selected. In our case, they were not. This enabled all applications to print correctly once again.
Apr 10, 2008 | HP LaserJet 2420dn Printer
Computers & Internet Logo
246 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
