Need codes for a zenith remote number zna110bl
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
1997 Zenith tv, 27" i cannot find a remote or proper access code that will work on it.
Try out the Harmony remote - tad more expensive but very flexible and comprehensive.
Sep 06, 2017 | Zenith Televison & Video
Hi, i need the codes for an old zenith tv, i lost my chart of codes, can you help me up please?
The JASRM24912 uses a 4 digit code and there are a number of codes for Zenith tvs: ZENITH ......................0329 0247 0252 0266
......................0288 0226 0227 0338 0347
......................0353 0358 0245 0229 0310 0232
......................0376 0377 0279 0368 0243 0405
The manual and the code lists are available here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
I hope this helps.
Nov 05, 2010 | GE JASRM24912 Remote Control
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
I need my tv zenith codes number
http://www.thompsontv.com/zcodes.html
Sep 12, 2009 | Zenith DBZN-311 Remote Control
Can not find code to program my tv and remote control I have a zenith television and a zenith universal remote
One website (Thompsontv.com/zcodes.html), says that the setup code for a Zenith TV, using a Zenith universal remote, is one of the following numbers: 101, 142, 149, 177, 175.
If these numbers do not work, visit the Zenith website (Zenith.com) for contact info.
Hope this info helps you out. Please take a moment to rate this solution,using the rating system below. Thanks.
Jul 16, 2008 | Televison & Video
Zenith remote codes
0711 is the Magnavox universal; if this fails, we will need the exact model number of both the remote control and the TV - ifyou do not have both model #'s do not bother posting back
Jun 09, 2008 | Philips Magnavox 27MS343S 27" TV
Need codes for my zenith tv remote
What´s the control manufacturer?
Feb 21, 2008 | Zenith C27A24T 27" TV
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
