Question about Cell Phones
I WANT TO USE OTHER SIM - Cell Phones
Put in sim card and comes up insert sim ?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Nov 02, 2012 | Cell Phones
HTC SNAP SIM CARD FAILURE
First All Check:
Last Option:
Sep 01, 2012 | Cell Phones
Sim solution
First All Check:
Last Option:
Jul 28, 2012 | Nokia 3600 slide Cellular Phone
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 | Cell Phones
Dual sim china mobile show on screen invalid sim
I HAVE A CHINA SET SIGMATEL S90 DUAL SIM ONLY SIM 1 IS WORKING FOR SIM 2 SHOWS AS INVALID SIM FROM FEW DAYS PLEASE SOLVE THIS PROBLEM
BABU
9035040544
May 27, 2010 | Sharp Cell Phones
Sim card
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
I woke up andMy phone says to insert sim card but it is in
  1. Power off phone
  2. Remove battery and SIM
  3. Reinstall battery and SIM
  4. Power on phone.
Problem solved? If no, then,
  1. Power off phone
  3. Put your SIM into another phone.
  4. If the SIM works with the other phone, then:
  • Clean the contacts of your phone's SIM receptacle.
  • Blow near the SIM area of your phone.
  • Reinstall SIM and Problem solved! If stills without recognizing your SIM is time to take your phone to service.
  1. If your SIM doesn't works with the other phone, then replace your SIM.
Nov 23, 2009 | Computers & Internet
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
