Question about Samsung SGH-t629 Cellular Phone
Others can't hear me.
When calling other people I can hear their voice, but they cannot hear me. Is this a technical problem, or a simcard issue? I have t-mobile if that makes a difference. I tested to make sure it was not just the one phone by calling other numbers. I even turned it off, and removed the battery and simcard. What can I do?
  • modeltj Nov 02, 2007
    I can hear people talking to me, but they cant hear me talking back. The phone is less than 2 weeks old. It will say one second I have 5 bars, and then go to no bars, when I havent even moved from the spot I was sittin in. Other people from the same provider can be next to me with a different phone, and they have great reception.
    Brigadier General:
  • 7,752 Answers
SNKR2468 - you need to take the phone and ahve the microphone replaced.
MODELTJ - microphone needs replacing on the phone
Posted on Jun 29, 2008
SOURCE:
I cannot hear when i call, i can only hear when i put on the speaker. why?
you have just one choice to get it to ur provider or to send it to nokias if warranty still available.
Apr 10, 2013 | Nokia C7 (8 GB) Smartphone
Cannot hear my voice in microphone
These instructions are for Skype 4.2 for Windows or below. Before continuing, we strongly recommend that you upgrade to the latest version. For Skype 5.0 and above, refer to these instructions. If you're not sure which version of Skype you're using, it's easy to find out.
If the person you are talking to in a Skype-to-Skype call cannot hear you there are a number of steps you can take in order to help you set up your system correctly so that others can hear you.
Try calling Echo123. If you can hear your own recorded voice then your playback device (headphones, speakers, etc) and microphone are set up correctly and the problem might stem from low internet bandwidth, or that the person you are calling has not set up their sound devices properly.
If you cannot hear your own voice in Echo123 check that your microphone is on.
Test Echo123 again to see if the microphone now works..
THANKS.
If none of these steps work you might need to adjust your computers sound setup. Have a look at our Sounds Setup Guide.
Also check out our Troubleshooter for more help with common sound setup issues.
Apr 28, 2011 | Skype IM
No dial tone/ others trying to call get busy signal
there is no problem with your phone.Because the main problem is the simcard you are using...try to buy a new simcard
Jun 20, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Bad Service with LG VU - Voice Breaks up
i have the same phone but it doesn't do anything like that
Apr 04, 2009 | LG Vu CU920 Cellular Phone
Hearing problem,on nokia
It's dreadful when you are having audio issues. I totally understand!! First, you wanna make sure you don't have your phone on mute. Now, just remove battery and simcard. For about 30-45 seconds. Put all back together. Ensure there's signal. Make a test call in and a test call out. With speaker phone and without speaker phone. If you keep having this issue. Move your simcard to another phone which uses the same carrier. This will determind if the audio issue is simcard related or phone related. After doing the simcard swap, and by chance the simcard is fine. Then, we move onto the phone. It's something with the software. Fix by going through a master reset. I suggest the pound star code: using *#7370#. When asked for the pin number or security number, default is 12345, or which ever number you may have put in. The phone will shut off, shut back on. You'll notice the ringtone and the wall paper are back to as if you just got the phone. Do a test call in and out. With and without speaker phone. Still an issue with the audio. Then it's a hardware issue. Contact your carrier in regards to warranty. Or, you can contact Nokia for the repair and return program. www.nokiausa.com
Cheers!
Feb 04, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Other people can't hear me during a phone call.
You may have used the voice simulation feature. To check this, go to Settings, General call setting, then scroll down to Voice changes, select voice mode and make sure its set to normal
Jan 08, 2009 | Dual Electronics N99i Cellular Phone
Maestro 4040 voice command unlock codes?
I think you are on the wrong track!
Why not call Magellan's Technical Support and raise the issue of misleading advertisement. If you argue it as well as I did you will end up with YOUR OWN VALID code based on the serial number of your unit FREE OF CHARGE.
How is it for the BEST SOLUTION?
Oct 09, 2008 | Magellan Maestro 4040 GPS Receiver
On other end caller cannot hear my voice...(nokia 3100)
most probably, mic problem. consult phone technician nearby.
Aug 06, 2008 | Nokia 3100
Samsung SGH-t629 Cellular Phone Logo
51 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
