Question about Sony CRX320EE CD-RW/DVD-ROM Combo Drive
DVD/cd-rom will read disk - Sony CRX320EE CD-RW/DVD-ROM Combo Drive
SOURCE: Sony combo drive
Can you please explain more the problem so i can help you? CD-R is the same as CD-ROM!!!! best regards AMINE
Posted on Aug 27, 2007
ctf1800
  • 4402 Answers
SOURCE: dvd problem
have you tried different brands of dvd's?
and have you tried a dvd movie?
if you can not view a dvd movie then it's toast just buy a new one.
Posted on Dec 06, 2007
  • 1019 Answers
SOURCE: Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 24, 2008
kamal1984
  • 1383 Answers
SOURCE: sony combo dvd rom dont open dvd
check your lense with deffferent dvds if it works then it is ok if it not works then you have change or repair lense if it is warrenty take it to service shop they replaced it.
Posted on Jul 13, 2009
SOURCE: why my [sony cd rw dvd rom] will not detect a blank dvd disk
my computer CD-R broke but i have DVD-R both how can i burn mp3 disk on the DVD-Rom driver it wont work it says please insert black cd but there is blank disk in it how can i burn cd on the DVD-R drive.
Posted on Oct 10, 2009
My Dvd Writer Can't Read Dvd Disks But Can Read Cd Disks
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps you
Aug 25, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
It won't see a blank disk or write to it
CD-ROM and DVD-ROM. ROM stands for "Read Only Memory". On the other hand, CD-RW, DVD-RW stand for "Read/Write". So, if the specs of your laptop say that you only have a DVD-ROM, not COMBO or something ending in RW, then you laptop's optical drive is simply not built for writing to discs.
Feb 15, 2010 | Sony Computers & Internet
I CAN NOT READ DVD
Hello my friend, Thus you Disk Rom is a DVD? if it not DVD then it cannot read DVD but if it is DVD then try to insert other DVD or CD Disk to check if it really works. Also try to clean your ROM with a disk cleaner. Then if all of the steps are done and still the result is same problem then ship it back to the suplier or buy new ROM. Thanks
Jun 17, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Optiarc dvd rw 7530B will read CD,CD-rom but No DVD, DVD-rom
it can read cd but not dvd isnt it. this cause your dvd rom faulty pls try borrow from somebody and replace it first see how ok
Jun 07, 2009 | Computers & Internet
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Having a trouble with my DVD-ROM - IBM ThinkPad T42
Internal the pickup assy. (the laser) there are three components that read the discs, one for DVD one for CD and one for the DVD-ROM its likely that the DVD-ROM laser has gone out. Take the drive out and get the part number and look it up online on ebay or the like :-)
Sep 13, 2007 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
Sony CRX320EE CD-RW/DVD-ROM Combo Drive Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
