Question about Graco SNUGRIDE 35 1780582 EDGEMONT
I was wondering what the expiration date was on this product?
Does Hoover Premium Pet Carpet Detergent expire?
If there is an expiration date, it probably is encoded in the product ID.
Sep 19, 2016 | Hoover Vacuums
Graco princeton car seat with base owner manual model 7429VL manufactored in 051102
This car seat that has expired! Car seats are good for anywhere from 5-8 years. Afterward, they are considered expired. You need to buy a new car seat.
http://baby.about.com/od/healthandsafety/f/car_seat_expiration.htm
Sep 17, 2012 | Graco SnugRide - Clover
I was just wondering what the expiration date is on your mascara if it is unopened?
Hello Dear
Expiration date on mascara shows that it would may be get dry on this date. if you unopened the mascara for a longer time after the expiration date, you would not be able to use that. or may be it would have a bad effect on your lashes.
regards
(Please donot forget to rate)
Mar 16, 2011 | Tarte Increases Lash Volume By 424%...
What is the shelf life of cosmetics?
The shelf life for eye-area cosmetics is more limited than for other products. Because of repeated microbial exposure during use by the consumer and the risk of eye infections, some industry experts recommend replacing mascara 3 months after purchase. If mascara becomes dry, discard it. Do not add water or, even worse, saliva to moisten it, because that will introduce bacteria into the product. If you have an eye infection, consult a physician immediately, stop using all eye-area cosmetics, and discard those you were using when the infection occurred.
Among other cosmetics that are likely to have an unusually short shelf life are certain "all natural" products that may contain plant-derived substances conducive to microbial growth. It also is important for consumers and manufacturers to consider the increased risk of contamination in products that contain non-traditional preservatives, or no preservatives at all.
Consumers should be aware that expiration dates are simply "rules of thumb," and that a product's safety may expire long before the expiration date if the product has not been properly stored. Cosmetics that have been improperly stored - for example, exposed to high temperatures or sunlight, or opened and examined by consumers prior to final sale - may deteriorate substantially before the expiration date. On the other hand, products stored under ideal conditions may be acceptable long after the expiration date has been reached.
Sharing makeup increases the risk of contamination. "Testers" commonly found at department store cosmetic counters are even more likely to become contaminated than the same products in an individual's home. If you feel you must test a cosmetic before purchasing it, apply it with a new, unused applicator, such as a fresh cotton swab.
Nov 22, 2010 | Health & Beauty
My Norton 360 product has been automatically renewed but says it has expired. Please advise
Hi, The usual issue about the expired message on norton is:
  • check the time and date on the computer
  • or, the product is not up to date
you can uninstall and reinstall the product again if it is renewed:
  1. Download Norton uninstaller from here:
www.norton.com/nrt 2. THen download the installer from, here: www.norton.com/n360s_4 3. then run liveupdate to get the latest updates 4. then run quick scan
Cheers!!
Aug 20, 2010 | Computers & Internet
System refuses to accept valid expiration dates beyond 2011
If you haven't solved this already... it sounds like a slightly older version of PCCharge. Go to Setup -> Configure System. You should see a box that says something along the lines of "Last Valid Year" Set that to something like 19. This will set the program to accept cards with an expiration date of up to 2019.
May 10, 2010 | Go Software Inc. PCCharge Pro...
Graco snugride infant carseat
first off, make sure of the age of the car seat as there have been safety recalls with this model
here is the web site link to the graco company
http://www.gracobaby.com/customerservice/recall.aspx?categoryID=1
from the home page of www.gracobaby.com you should be able to find the instructions based on the product/serial number on the car seat
Oct 19, 2007 | Graco SnugRide 8649
Graco SNUGRIDE 35 1780582 EDGEMONT Logo
42 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
