Question about Dryers
Replace belt in simpson sirocco 455 dryer - Dryers
SOURCE: I'm having a problem re-fitting the drive belt to
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Cheers,
Andy B.
Posted on May 02, 2009
SOURCE: diagram of how to replace drive belt on simpson
Diagram of how to replace drive belt on simpson
Posted on Jul 31, 2009
  • 17 Answers
SOURCE: My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Posted on Nov 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: how to fit a dryer belt simpson sirocco 500
Hi
Thanks for using FixYa. If its loose then I don't think you have bought right belt, please check this video on how to replace the belt. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: clothes dryer stopped working while
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 12, 2011
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Clothes dryer stopped working while it was working Simpson Sirocco 455, what could be wrong?
heatman101
Jul 26, 2011 | Dryers
Simpson Sirocco 350 Dryer cuts out after 5 minutes I am told it is the heat sensor attached to the red button inside the door but not sure how to access the sensor to replace it.
Its probably NOT the sensor causing the problem. Have you checked the fan belt, that its not broken, come off the pulley or stretched? Put your hand over the airvent outlet at the back after it has been running a few minutes, if there is a lot of hot air coming out, then belt is ok. If not, replace the fanbelt with a new one, and problem will be solved. The sensor pops out because of overheating - usually because either the fan belt is broken or stretched, or the lint filter is blocked. Hope this helps!
Jun 04, 2010 | Dryers
I need to replace a simpson sirocco lint cover spindle Do you no where i could purchase one. the plastic casing on the spindle has broken and the lint cover will not stay on.
I'm not sure where you can get one as i am in australia but an appliance spare parts outlet should have one or order it in for you,alternatively try simpson or electrolux.
Jun 01, 2010 | Dryers
Nov 05, 2009 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
I'm having a problem re-fitting the drive belt to my Simpson Sirocco 455 tumble dryer. After installing the belt around the drum, drive pulley and tension wheel, I align the front end of the drum with the...
Cheers,
Andy B.
May 02, 2009 | Dryers
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
19 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
