Question about HP Computers & Internet
Balco b93 kalibreren - HP Computers & Internet
JOEY BALCOS ILANO
HI :) CAN I HAVE YOUR NUMBER :)
Apr 10, 2014 | pipl.com
B93-366 Indoor Unit Ours is mounted on the wall in a new room addition (3 years ago). Has worked fine. Used it with remote control a few days ago. It worked fine. Turned it off with remote control. next...
You will have to remove the front panel and check the fuse to make sure that it did not pop. Also check your breaker switch to make sure that your breaker did not pop. Those can be your really only two issues
Please rate
Jun 01, 2010 | Heating & Cooling
S40 Warning Lights
Faults can happen from day one, on. That is why there is a warning system.
If the warning light is on, you must access the computer system to access which fault code is present. Many different companies manufacture tools to do this from an inexpensive generic one from Launch Tech of China to the original factory unit made for Volvo by Balco. Depending on the fault code, the most common one that I see is caused by the fuel cap either installed incorrectly or not fully tightenned. Check your fuel cap and if it is not installed correctly or not fully tightenned, please re-install. If the fuel cap was the problem, the warning light will go off by itself in a few days.
Jun 07, 2008 | 2005 Volvo S40
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
