Question about UClear HBC200 Force Bluetooth Intercom
HBC200 picking up muffler at 85 kmh and under. Have Two Brothers muffler. Thank You
What would the out come be if I remove just my muffler on my 84 s10 4x4 Chevy blazer iv bin told it has a Lil more power I just want to no what the good and bad is bye removeing it?
Keep your muffler Matt,get rid of your catalytic converter,you will have more power and better gas mileage,took it off my 85 Nissan 720 truck.
Mar 31, 2015 | Chevrolet Cars & Trucks
Hi, have a stihl fs 85, runs fine for 10 minutes, then just cuts out. tried cleaning carb, muffler.
Two things spring to mind, fuel tank breather, to rule this out slacken off the filler cap when the machine starts to die, if it picks up again change the tank breather, or the ignition coil is breaking down when hot, this would require a replacment unit.
Dec 16, 2012 | Stihl FS 85 Weed Eater
How can i get my guages working and dash lights on my 84 trans am
try checking the wires too make sure they werent disconnected and left. if nothing, try replacing the gauge panel. what i had to do to my brothers 85 camaro
Aug 02, 2011 | Pontiac Trans Cars & Trucks
My brothers O2 sensor went out on his 97 2.3l ranger and we are having an hell of an time finding. Could you please tell me in detail where both of them are. thank you
They should be located before and after your cat converter in your exhaust system. Im not familiar with this vehicle but all O2 sensors are mounted basicly in the same area.
Apr 10, 2011 | Ford Ranger Cars & Trucks
2001 e150 van ,at idle in drive trans has raddle,like metal objects banging around inside somewhere.sound dissapears at cruse.have any ideas what this could be.is this a serious problem? thank you...
coud be the shroud on the muffler under the van or loose muffler hangers .........
but could be anything loose under or if inside check mouldings seats dog house console dash .....
Oct 21, 2010 | 2001 Ford Econoline
Exhaust Pipe broke/Rust on muffler
Flex pipe will work, or if it's a straight section of pipe you can buy a universal piece of exhaust tubing with flared ends, trim off the rusty ends on your original pipe with a hacksaw or Sawzall and slip in the new section. Clamp it with 2 muffler clamps and you're set. Total cost should be under $40.
Apr 10, 2010 | 2000 Saturn L-Series
I have an Explorer Sport trac 2001 (2005 in Venezuela)... last week I took her to complete a service on the fuel injectors and also replaced spark plugs as she is very slow to pull up.. I have checked...
If the light came on it should have a code for a scanner. That would indicate the problem. But there are a few things to look at. Under the airhorn which bolts to the intake manifold there is a breather groove for the EGR valve. This groove must stay clean.
Since you are demanding more EGR flow with higher speeds the blocked groove is causing a restriction and causing the other components to trip a warning.
I do not know your Pollution equipment. On older U.S. cars there were airpumps that were belt driven and some had a type of air filter that needed cleaning.
Another part called a (TPS) throttle position sensor can affect the engine performance.
Nov 11, 2009 | 2001 Ford Explorer Sport
Vacuum reservior 1996 Jeep Grand Laredo
The vacuum res. is a black (can,football,round) shaped item. I do not remember if it is behind the bumper on the pass. side of car. It could also be under the hood on the pass. side. Pass. side under the hood are vacuum lines, follow them, one will go to the res.
Nov 02, 2008 | 1996 Jeep Grand Cherokee
UClear HBC200 Force Bluetooth Intercom Logo
Top UClear Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an UClear Radio Communication Expert? Answer questions, earn points and help others
