Question about Avaya 8180 Wireless LAN Controller - WL81WCE81E5
My ap 8120 is not deact on the controller 8180
Our network brief we have one controoler 8180 and ap 8120 now poe switch and ap able to ping on 8180 controller
System LED is off
how far is your cable run? if it is more than 100m or 328 feet you will recieve video when plugging into the analog but nothing on the server. if this is the case you need to install an additional switch at about 80-90m or 262-295 feet and run the additional cable from there. you also need to install a POE injector at the camera point.
Oct 26, 2013 | Samsung SNB-3000 1/3 Inch Progressive...
Network is: 2x AT-FS713FC/SC (fiber connected with each other) behind the "remote" FS713FC i have one motorola acces point (192.168.1.48 motorola ap5131). This AP functions properly. I added a...
You got to check a few things prior to perform any troubleshooting step.
1)whenever you face a disconnection check both end FO converters and try to figure out which one lights are blinking and which are not blinking in both ends at the same time.
2) are both the converter is similar make or not? If not please specify both makes.
3)How many devices are connected on both end after the AP's(approx)? Is there any switch or hub also present within the same network?
4)whenever you face a hang/disconnection position disconnect and reconnect power from one of the FO converters and see what happens then disconnect and reconnect power in the other end and see what you get.
Please revert back with the above detail and I feel I will be able to help you out.Rather you will be able to find out where the issue lies by applying the above steps.
All the best.
Nov 14, 2011 | Allied Telesyn AT-FS713FC ST-10...
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
I have a HP ProCurve MSM 410 AP. It will accept clients and then in 20 minutes it starts dropping connections..and will not let them back on with a restart. I have poured over the specs for both AP and...
I'm having a very similar issue with 5 MSM410's (at 2 differant locations), purchased at the same time, from the same vendor.
With 2, when connected using PoE Injector, the AP gets hot (at the Data/Poe port), and only permits 3 devices to connect before the devices start losing the ability comminicate beyond the AP (i.e. I can logon to the AP with the Web Interface (WI), but cannot ping the DHCP server or even the Gateway device on the other side of th AP from the devices, but can ping both directions without issue from the AP's WI). HOWEVER; when connected using the PoE from a Cisco ASA-5505 (port 0/6 or 0/7) the devices work flawlessly.
- For this site, I replaced the Power Injector first, then replaced the AP. No change
- When connected to the PoE on the Cisco the unit does not run "Hot".
With 3 others at another location, they only allow 3 devices to connect and will disconnect any devices previously connected. These 3 are supplied PoE from Dell PowerConnect Gigabit Switches (also used to supply power to the VoIP and PoE Security Camera's), and also run Hot at the Data/PoE ports. We have not tried power injectors at this site.
I've tried to find any indication of how to adjust the PoE and Data Port settings to resolve this, but cannot find anything, and this appears to be a unique issue, as noone I have contacted has ever experianced it.
- Mike
Mar 28, 2011 | HP ProCurve MSM410 (J9426A) Pre-802.11n...
I forgot the code
this is all lg hard reset code you much enter it
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
LG
47328545454#
Or
277634#*#
U8180 old ...............49857465454#
U8180 new .............492662464663#
U8330 ...................637664#*#
U8360 ...................*6*41*12##
U8380 ...................525252#*#
ALL LG 2G : 2945#*#
8110 & 8120 : 277634#*#
U8130 & U8138 : 47328545454#
8180 old sw : 49857465454#
8180 new sw : 492662464663#
8330 : 637664#*#
8360 : *6*41*12##
8380 : 525252#*#
LG 8550 885508428679#*#
Phone
Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone
Unlock Menu Code
Older phones 2945#*88110#
U880
was told that unlocking code for the phone is "0794070061"
and method is to enter 142358#*#
but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside).
Plz help how to unlock it permanently
Mar 03, 2011 | LG Dare VX9700 Cell Phone
I bought a used cell phone and he forgot his password. How can i reset to start using the password?
Code to reset phone :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
i hope this helpful
thank you for uisng fixya
Feb 09, 2011 | LG enV3 VX9200 Cell Phone
Hi, can anyone brief me the steps How to configure the D-Link DES-3026. Dinesh.
This switch is a plug n play device. No need to configure anything for basic use.
If you want to go for advance settings, You can log into the switch via webconsole and then providing the username and passwords you can loin and do the advance configurations like VLAN settings, Speed/Duplex settings, QOS settings etc
Oct 28, 2010 | D-Link Dlink DES-3028P Switch 24-port...
Radio0 and radio1 "not installed" problem on Cisco 1131AG
check that you have enough power on the PoE to power up both radios. Switch one off for clarity and see if 1 powers up. Also check the log of the AP and the PoE switch as it will report the power related issue if it is a pre- PoE approved switch
Mar 12, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Avaya 8180 Wireless LAN Controller - WL81WCE81E5 Logo
44 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
