Question about Husqvarna Decal,Huv 4421Gxp, Orange, Ps - HVP 603 00 34 98
I have a husqvarna HUV 4421 that has lost rear wheel drive. I suspect a broken axle. Is this a common problem or should I look check for a different problem?
    Sergeant:
  • 417 Answers
This is a forum for chainsaw issues, please find the correct forum that applies to your machine or problem. Thanks!
Posted on Nov 23, 2013
My YTH2648TDRF has only one rear wheel that engages the mower, shouldn't both rear wheels drive?
The rear drive uses a differential to drive the rear wheels, just like a car, the differential drives the wheel with least resistance, to enable the wheels to revolve at different speeds when going round corners; so it's quite normal for only one wheel to be driven. If your mower is having difficulty with slopes (do you call them grades?) I suggest you fit a new drive belt, a slipping belt is the most common cause of low power. Hope this helps.
Jan 12, 2016 | Husqvarna Garden
Tractor will not move under it's power.
Make sure you routed the drive belt correctly there might be an idler pulley you missed, make sure the belt is firmly on the trans axle, if so, put the rear end up on blocks and see if the wheels turn then, if they do put pressure against both rear wheels and see if you can stop them. If these wheels are on keyed axles and one key shears it wont drive because the drive wheel is the one that turns the easiest. so pull the wheel and check for a missing or sheared key. Replace key for an easy fix.
Jan 07, 2016 | Husqvarna Garden
Rear wheels not engaging what can I do to troubleshoot the awd?
awd drive cars have a differential action between front and rear wheels and there should be a switch that allows you to lock up that action for adverse conditions
if the rear wheels are not working , it is because there is no drive action to the front wheels ( front wheels spinning or broken drive shaft to the front)
all wheel drive means that in normal driving when there is traction on all 4 wheels that the power is transmitted evenly to all 4 wheels
It is not 4 wheel drive where power is applied to both axles or in the event of one axle loosing traction the other axle still drives
Dec 15, 2015 | 2007 Lincoln MKZ AWD
09 stang GT/CS conv. play in Rt.Rr wheel lugs r tight. I can move wheel and rotor in and out a lil bit. No grinding noise when wheel spins.
There may be a slight amount of end play in each rear wheel if rear wheel drive. This is normal axle end play with a solid axle. If the rear axles are CV joint type with a small differential, suspect a loose/worn wheel bearing/hub assembly
Jul 01, 2015 | Cars & Trucks
Proflex 18
Jack the mower up at the rear and make it stable before doing any work on it, remove the rear wheels by removing the hub caps if they are still on the wheels and remove the cir clip and washer on each wheel and remove the wheels. there will be a key way on each axle when you remove the wheel, make sure they are put back in their place when assembling the wheels onto the axles or you will not have any drive on the wheels
Remove the drive belt, brake rod etc then support the trans axle before removing the retaining bolts and removing the trans axle from the mower. hope this helps.
If you are not mechanically inclined then you should leave the repairs of the trans axle to the mower repair shop unless you are buying a new or reconditioned trans axle, in which case you can fit the new trans axle in the reverse order of removal.
May 29, 2014 | Husqvarna Garden
Ford escape 4wd
That vehicle is front wheel drive,the rear axle is only engaged for 4 wheel drive,would suspect the actuator on the rear axle.
Dec 26, 2013 | Cars & Trucks
Honda hrr2163tda rear drive problems
remove the rear whheels and check the drive lugs on the axles to see if broken or just rusted or stuck down
Feb 21, 2013 | Garden
Getting the tire off the axle of a husqvarna yth 21 k 46
if its a rear axle and you took the clip off and the wheel will not move just change the tire on the tractor and leave the wheel on
Apr 29, 2012 | Husqvarna Garden
My 42" Husqvarna (model #917.279240
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
May 15, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I just bought a 1994 chevy silverado 4x4. It had been sitting for a couple of years (started often). It moves forward but the passenger rear wheel seems locked up in reverse. After taking the wheel off we...
The brake drum may be rusted to the shoes. Try tapping on the drum all around with a hammer, trying to get the drum to pull off. Taking the axle out is somewhat complicated on these models, however I would rather believe you have a brake drum problem.
Aug 02, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Husqvarna Decal,Huv 4421Gxp, Orange, Ps - HVP 603 00 34 98 Logo
95 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
