Re: Panasonic CTV TC-20V50P
Vertical line dispaly, screen on plyback is already adjust.. what would be posible.. tnx
    Brigadier General:
  • 6,966 Answers
Hi, Possibly an open resistor in the 100 Mega Ohms range (On some models as high as 470M). Either in series or parallel to ground of the G1, G2 or Screen supply. This would normally be in the PCB at the rear/neck of the picture tube. Of course, it is also possible that the Screen adjustment or the FBT itself is already faulty. Hope this be of some help. Good luck and kind regards.
Posted on Oct 08, 2007
SOURCE:
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
How do I get rid of green line?
your problem is a faulty T CON BOARD.
Part number TCON BOARD 6870C-0060F
hope 2 help
www.bostonrecycling.net
Jun 30, 2012 | Panasonic TC-32LX70 Television
Panasonic tv model no.TC-21RX30P
Hello
What is the problem with your Panasonic TV? you only mentioned its model number here. No problems reported. Please clarify the problem with details. OK.
Feb 14, 2011 | Televison & Video
How do you adjust the vertical lines going across my screen?
The vertical deflection circuit of your tv has a problem.
First, try to replace the vertical ic. This ic can be found near the plyback or horizontal section. It is a linear ic with heatsink.
If nothing happens after replacing the ic, replace all the polarized capacitor near the ic and resolder the components at the vertical section.
Jan 18, 2011 | Durabrand BH1304D 13" TV
No picture with sound
check the tail end of the picture tube do you see a light on it?that is the heater of the picture.without it your screen will be black. If there is no light from the heater there should be an open resistor connected to he heater replace them. .next check the screen adjustment of your plyback.screen adjustment is right in the body of the plyback there are 2 adjustment in there the upper is the focus adjustment and the lower is the screen adjustment turn it clockwise untill you reach the preferred adjustment.. tnx
please rate my help
Jun 05, 2010 | Panasonic CT-27SL14 27" TV
Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Mar 20, 2009 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
My HT3061P Prima tv, has the black screen, but the audio is very good.
adjust first the screen. it is a knob at the back of plyback.(lower knob),if the has vertical line ,then the section had a problem.try to resolder the vertical IC or else change the IC.
Oct 15, 2008 | Prima CV2011 TV
No picture but sound ontv
first adjust the screen knob at the back of the plyback and then check the screen ,if you see a vertical line ,then vertical IC is busted or else lose connection.
Sep 14, 2008 | Sanyo HT32744 32" TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Ekse
