Question about Canon LASER SHOT LBP 3300 Printer
A4 borderless print
How can borderless print
Print head alignment nozzle
Borderless print ?
Set custom page as exactly paper size. Set borderless expansion to max. Select appropriate paper media type.
Sep 29, 2013 | Epson Stylus 1400 InkJet Photo Printer
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I am getting paper jam error message after I try to print on photo paper
Some printers detect the type of paper you are using, and print accordingly. Do you have photo cartridges installed? If not, that will trigger an error message. Try putting a smaller amount of sheets in the paper feed- that can sometimes trigger an error message, I've read in reviews. Double check the printer to make sure there, indeed, isn't a paper jam. The type of paper one uses with certain printers can be an issue, so google your printer make and model number and then type something like suggested paper type, or things similar, and you will get some sites that discuss problems with different printers and paper types, and also suggestions of which paper will work well with which printer.
I couldn't find any specific information since I didn't have a make and model number, but hope this general information helps.
Good luck, and thanks for using FixYa.
Sep 07, 2010 | Office Equipment & Supplies
Hp 6500 misaligns printing on labels. can print same labels on other printers.
I determined that if you set the paper type to
" Borderless A4" (in printer properties/preferences- just tick the "borderless" box) then all works OK.
Sep 02, 2009 | HP Officejet 6500 Wireless All-in-One...
When printing a picture on a full A4 page for a broacher I get a thin white border. I need it borderless incase movement in the printer.
You must select borderless in the print options/preferences menu.
What program are you using to print and I may be able to help more.
Jun 19, 2009 | Epson Stylus C67 Photo Printer
Borderless printing kodak 5500, clear coating business cards
Go to printing preferences of the particular program and then select Borderless . THESE ARE THE SIZE OF PAPERS SUPPORTED IN Kodak printers.
  • 3½ × 5 in.
  • 4 × 6 in.
  • 4 × 8 in.
  • 4 × 12 in.
  • 5 × 7 in.
  • 6 × 9 in.
  • 8 × 10 in.
  • A
  • A4
May 07, 2009 | Kodak ESP 5 Printer
MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Jan 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How can I get A4 size borderless prints
From what I can see, this printer can only do borderless prints onto 4x6" paper only. Larger print jobs such as your A4 will have a border.
artifixit
Dec 19, 2007 | HP PSC 1410v All-in-One Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon LASER SHOT LBP 3300 Printer Logo
29 people viewed this question
old marine
old marine
