Question about HP w2207 Monitor
Flashes red, blue, green, black, white in sequence when idle
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
When you turn on the TV the screen flashes through a sequence of red, green, blue, white & black screens. Unable to access menu & no sound. TV Model LG 27LC2D
Sounds like it's in a service burn-in mode. LGs need a service remote to de-activate. Probably easy for a local LG shop.
May 03, 2010 | LG 37LC2D Television
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Connection
Hi...there,
Try Red, Green, Blue that is a sequence. settings all to 100% Have a nice day!
Feb 02, 2009 | iiyama Vision Master 404 Monitor
HP w2207 Monitor Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
