Tv shutdown with brithness color
When turn on my tv it turn off emmidiately with bright color on display
  • 115 Answers
Check the inverter circuit board
Posted on Nov 19, 2013
Brightness problem
Its digital processor board should be checked. There is no repair to this baord. Only card base replacement can be done. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 25, 2013 | Panasonic Viera TX-32LX70 32 in. LCD TV
My Tv started with flashing red/orange colors. Then later the screen turned red/orange and the TV shut off. When I attempt to turn it on again, the screen stayes red for a few minutes then shuts off.
The problem based on the model number is in or around the red picture tube---the bright red screen causes the set to draw too much current and the shutdown circuit detects this and turns set off--self protection.
Each picture tube (3) has a IC chip on the board connected to it--shorted chip or bad picture tube.
Shop repair in most cases.
Dec 02, 2012 | RCA HD56W58 56" TV
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
My picture is dull and its really bright not many colors are displaying what can i do to fix it?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 21, 2010 | Philips 55P8341 55" Rear Projection...
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
Axion handheld tv. No picture at all.
I have on and if the batteries start getting weak the screen display brightness is the first to stop working. Double check that, if you are on AC power try sliding the brightness control from dim to bright a few times and see if the rheostat has corroded. Those are a few of the quick checks you can try, let me know. Jay
Jan 21, 2008 | HandHeld Entertainment Axion 2.5'' TFT LCD...
New screen not as light as it should be
you didnt get the right replacement for his model thats why brightness is low and also why the display buttons are in reverse if he continues to use it it may cause long term damage and may affect the correct screen if and when he gets it
Oct 29, 2007 | Toshiba Satellite 5005-S504 Notebook
TV turns off when bright colors displayed
Yes your fix is in the threads here, I have answered many of the question on Mits as of other sets, you have a problem with this set Shutdown at bright scenes, it is a known problem and the answer lies here on threads, just search. This keeps from having to keep repeating the same answer. Thanks, hope this helps!
Dec 16, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
