Question about XFX Computers & Internet
STEP BY STEP PROCEDURE FOR REPLACING THE BIOS CHIP AND RESETTING BIOS
I NEED TO REMOVE AND REPLACE MY OUTDATED BIOS CHIP AND INSTALL A MORE CURRENT ONE SO THAT I CAN UPGRADE THE DRIVERS AND CHIPSET DRIVERS FOR COMPATIBILITY PURPOSES FOR BETTER COMPATIBILITY WITH LARGER HARD DRIVES AND NEWER GAMES.I NEED TO KNOW IF BACKUP BATTERY NEEDS TO BE REMOVED DURING PROCEDURE AND WHAT POWER IS APPLIED TO MY PC WHEN RESETTING BIOS SETTINGS AND HOW.I PRETTY MUCH NEED A STEP BY STEP GUIDE TO TAKE ME THROUGH THE WHOLE PROCEDURE.I HAVE THREE RELACEMENT CHIPS AND WOULD LIKE TO REFERENCE THE NUMBERS TO INSTALL THE MOST RECENT ONE.I AM CURRENTLY USING PUBLIC BROADBANT WIFI SO CAN'T FLAsh BIOS SAFELY.
    Brigadier General:
  • XFX Master
  • 3,400 Answers
ARDEN,A SIMPLE ADVISE PURCHASE A NEW MOTHERBORD.
Posted on Nov 19, 2013
5 Suggested Answers
cisco167
  • 36 Answers
SOURCE: Need to know the location of the bios chip on a esc g31t-m
Not all BIOS chips are removable. Your board uses a AMI Bios and u can quickly identify it by searching for the AMI symbol or lettering. If the Bios has a seat you can remove it: ttp://www.biosman.com/images/extaction_plcc_points.gif
If it is soldered on...sorry...u need a new MB.
But have you tried clearing the bios and then reflashing it?
Posted on Jun 06, 2009
1234s282
  • 144 Answers
SOURCE: Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Posted on Jul 02, 2009
bronk50
  • 27725 Answers
SOURCE: My computer stopped working some
ONE BAD LEAD?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Sep 18, 2010
cadillac02
  • 318 Answers
SOURCE: After replacing on board lithium cell, computer
You need to verify if your operating system is in tact. If you tried to replace hard disk with an operating system in tact I hope. If you have a windows XP cd, place it in the cdrom and boot it on start up...this will give you some diagnostic capability. Try removing battery as well...you may have wrong voltage. Remove battery on board then plug in computer then reboot. Battery is only for CMOS and not needed to operate computer. If it boots to an operating system you know what's up. Also, try resetting your BIOS with jumper setting then switch back after EEPROM reset.
Posted on Jan 11, 2011
Heater core leaking through floor vents.
Bad heater core you will need to replace it. About a 2 hour job, very easy to do:
Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
Remove the HVAC filter cover.
Remove the heater core/evaporator tube seals from the module.
Remove the heater core cover screws (1).
Remove the heater core retaining screws (1).
Remove the heater core retaining straps.
Remove the heater core.
Remove the rubber seals from the inlet/outlet pipes of the heater core.
Installation Procedure
Install rubber seals to the outlet/inlet pipes of the heater core.
Install the heater core to the module.
Install the heater core retaining straps.
Install the heater core retaining screws (1).
Install the heater core cover.
Install the heater core cover screws (1).
Install the heater core/evaporator tube seal from the module.
Install the HVAC filter cover.
Install the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
May 19, 2011 | Cadillac DeVille Cars & Trucks
As i was upgrading my bios, the power went off, after restarting no display, what can i do? my laptop is hp compaq nc6400
The machine will not start again until a new bios chip is installed or the
board is replaced.
On a desktop a procedure called "hot flashing" can be done but not on a
laptop unless you have the proper equipment and know-how.
Hot flashing is where you get and identical bios chip and replace the one on
the board. After the system is started you pull the chip will the system is on and
replace it with the bad flashed chip. Then you do a regular bios flash upgrade. The key is you
need an identical bios chip to start the process. On a laptop you need either and a identical
chip or the ability to write to the bad chip. Oh and I forgot to mention you need the equipment
to take the board out of the laptop case and get it running
One of two things needs to be done:
1) Replace the motherboard
2) Find someone who knows what they are doing and remove the chip and
reprogram it. You should be able to find one of these guys under Google.
May 12, 2011 | HP Compaq NC6400 Business Notebook
845gvm motherboard dead.no beep heard after removing ddr1 ram. how to confirm problem in ram or mbd mahesh maharashtra
Install your ram in another computer,
Or install an another new ram in your pc
If you want to know details can follow the bellow step,
Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios load fail save default,and press F10>enter.If the problem is same, change the RAM if you have a spare.
http://www.youtube.com/watch?v=3B9ff9ei7hk
If the problem is same ,take another ,mark on bios chip and remove Bios chip from socket , by thin screw driver ,and install itv again.
follow the pictore
http://www.computerhope.com/help/phoenix.htm
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
If the problem is same think *********** board has been defected and you should purchased. .
Hope this helps
Jan 29, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Step by Step:
@ECHO OFF
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
This message is seen on the laptop screen BIOS Damaged! Serviceman: Place maintenance disk in drive and press any key when ready.
The maintenance disk was simply a floppy with rewritten code on the first few sectors that bypassed any kind of checksum or self-diagnostic. Useful if you lost or forgot your BIOS password. Also let the tech into the bios to look at settings before replacing the chip. Back then it was cost effective. Nowadays they just replace the whole dang shebang.
Here are your main options, in order of attempt:
1. Hold down esc key when booting, see if you can get into bios. If not...
2. Remove battery and disconnect ac adapter
3. Gently disassemble case until you find a round coin-like battery
4. Go out, buy replacement battery, replace battery, then reverse step 3 and 2
If these steps fail, you've a bad BIOS chip, you could try to ...
5. ebay it.
Hope this helps!
Jun 04, 2009 | Toshiba Portege 3490CT Notebook
Hard crash, Need To Replace BIOS
If you're not good at sodering I'd suggest replacing the whole motherboard. Otherwise go Here <<< for a guide on the bios, and how to replace it.
Apr 27, 2009 | NEC PowerMate eco PC Desktop
Hello, I´woluld like to know where is the bios chip in a hp dv5-1000us. I need reset the bios chip after a unsuccesfully bios upgrade. thanx.
you cant reset the bios like that if you upgrade it wrong you need to get the chip replaced or flashed if it can be .it has to be done properly and professionally
Apr 13, 2009 | Computers & Internet
How difficult is it to install memory chip ugrade,,,
No problem in replacing the RAM chip modules, just make sure you ground yourself so you don't have any static electrical charge when you handle the memory modules.
Just power off the laptop before you remove and replace the RAM.
You won't lse anything as the info. is stored on the hard disk..
Jan 11, 2009 | Compaq Presario Notebook
Cant start
I've wrestled with many crc1 and crc2 problems on IBM machines here at my shop. This is a malfunctioning bios chip on the motherboard. There is no simple clearing procedure for this problem. The chip or the motherboard has to be replaced. I've had about a 25% success rate in replacing the chip, and 100% success by replacing the motherboard. Chip replacement is a delicate procedure in which you have to completely disassemble the machine remove he old chip with a soldiering iron and resoldier the new chip to the board. Soldiering on the motherboard is something I wouldn't recommend without experience. I would recommend replacing the motherboard, It's much easier, and possibly cheaper, since replacing the chip may or may not work. If you replace the chip and it doesn't work, then you're out the money for the chip, and you have to replace the motherboard anyway. The price for the chip is about a third the cost of a new motherboard. You can get a decent price for a good used motherboard for the T20 series from Ebay.
Jul 23, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
105 people viewed this question
Top XFX Computers & Internet Experts
David
David
KG John Justin
KG John Justin
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
