Question about Fishman Powerjack End Pin Active Acoustic Guitar Preamp
60 cycle hum fishman powerjack - Fishman Powerjack End Pin Active Acoustic Guitar Preamp
Fishman loudbox mini repair service manual
Request the repair service manual directly from Fishman.
Feb 03, 2018 | Fishman Music
My fishman clearwave 60 tuner will not give me a green light...it just jumps back and forth between sharp and flat, no matter how small the movement on the guitar key
You may have the tuner too far away from the guitar or the batteries may be going flat. Check to make sure that there is nothing blocking the microphone hole and that there is no other noises in the area which could be affecting what the tuner is hearing
Nov 23, 2017 | Fishman Music
Loud hum when I turn master above 2
Assuming there isn't an instrument plugged into it when it's humming, it will be time to have it recapped,
Oct 06, 2016 | Fishman Loudbox Mini Acoustic Guitar...
How to tune Fishman Prefix Premium blend
If it is the standard ISYS try
http://www.fishman.com/files/isys_preamp_system_user_guide.pdf
Jun 30, 2012 | Washburn NEW PRO WASHBURN ACOUSTIC GUITAR...
I have a fishman tele power bridge and one of the trandsducers, the A string, is not as loud as he other strings.And it seems to always have a buzzing problem.Not humming,but more like the strings is to...
I would first investigate if the string itself MAY have a problem. If the strings are old, say over a year, try a new set. The only other likely cause of the problem is the setup of the unit.
Oct 31, 2010 | Fishman Powerchip Preamp
Fishman Powerjack End Pin Active Acoustic Guitar Preamp Logo
Top Fishman Music Experts
Michial Gueffroy
Don Hart
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
