Question about GE Ovens
I have a GE oven, model JTP14. The oven will not heat up. The temp info stays at 100F. Nothing heats. The top heating element works when I switch on broiler. Can I fix this. Thanks
I have switched the breaker on and off to see if it resets, but no change.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Check element first then the fuse to element then controller
Posted on Nov 22, 2013
  • 1314 Answers
SOURCE: GE Oven Model JK1901BC
check power cord if oven light not working or burners then you have a power problem no there is no reset if you have power at the outlet then pull the range out take off the back cover where the power cord is and check there let me know we will go from there
Posted on Dec 31, 2007
  • 1314 Answers
SOURCE: OVEN TEMP STUCK ON 100F
check your house connections to the stove turn the breaker off first then reply to me
Posted on Jun 02, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: GE True Temp Oven not heating. Broiler works
    we bought a new oven
    Posted on Dec 15, 2009
    heatman101
    • 43501 Answers
    SOURCE: Oven/ broiler will not heat and bottom element slow to reach temp
    Check out this tip that I wrote about this problem...
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Posted on Apr 28, 2010
    How do I replace the bottom element of my GE oven?
    Hundreds of GE ovens, so can't give procedure, but problem is not necessarily the element - could be switch, connection to element, etc. Google GE (model #) lower element not heating.
    May 27, 2016 | GE Ovens
    Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
    The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
    Mar 16, 2016 | GE Ovens
    My GE oven JTP14 is not heating. Oven temp shows 100F, but elements not heating. The top element works when switched to broil.
    It is a good chance the bake heating element is bad. they can look fine and be bad. usually they are very easy to replace. Just make sure the power is off to the oven before attempting to remove the element. There is usually enough lead wire to be able to pull the element out from the front and disconnect the wires. If it has continuity the element is most likely good if not replace the element. If the element has continuity the problem is most likely in the control or wires from the control to the element..
    Nov 19, 2013 | GE Ovens
    Do I need to remove my wall oven GE model JTP14 to replace the heat sensor part # WB23T10002
    Usually you have to either remove the top of the oven or you can remove the back panel to access the sensor. or you can unscrew it from the inside and pull it out enough to unclip the harness and install the new one. if it is connected to the thermostat ( temp switch ) you have to remove the switch and install the new one and route the sensor the way the old one is routed which might involve doing one of the above options and removing the face plate the switch is connected to
    Sep 17, 2009 | Ovens
    Bottom oven doesn't heat after running self-clean cycle
    Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
    I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
    First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
    Jun 11, 2009 | Ovens
    GE double oven - bottem will not heat, top oven fine
    I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
    For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
    The lower oven switch is located behind the vent grill between the two ovens.
    GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
    Good Luck, DVS1936
    Oct 05, 2008 | GE JKP45 Electric Double Oven
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Heating element in GE Range Oven
    get the model number and order the exact repacement bake element
    Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Top oven will not heat up
    Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
    Nov 14, 2007 | GE JKP45 Electric Double Oven
    Ovens Logo
    124 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
