Question about HP Color LaserJet 2600n Printer
How to install transferbelt - HP Color LaserJet 2600n Printer
    Novelist:
  • 170 Answers
  1. Remove or slightly pull out Tray 2 (RM1-1916-000CN).
  2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
    assembly.
  3. Open the front door
  4. Remove the right cover (RM1-1858-000CN), carefully twisting the front edges of the side covers
    outward to remove.
    NOTE :
    To make the removal of the right cover assembly easier, release the tab on the inside of the cover.
  5. Remove the left cover.
  6. Squeeze the white link lever on the left side.
  7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
  8. Close the ETB.
  9. Remove the small black cable cover (RC1-5147-000CN) on the left side of the printer by carefully snapping it out of place.
  10. Remove one (1) grounding screw from the ETB harness.
  11. Pull out the white wire holder by pushing it up.
  12. Pull out the ETB connector.
  13. Remove one (1) screw from each hinge cam on both sides.
  14. Using needle-nose pliers, remove the hinge left cam (RC1-4249-000CN) and the right hinge cam (RC1-5311-000CN).
Remove the ETB. Use the following procedure to replace the ETB.
  1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side.
  2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE :
When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
Posted on Nov 24, 2013
SOURCE:
How to reset transferbelt of konica minolta bzhubc253.by using fusser replacement
To give you more details about resetting the imaging units, transfer belt and fusing unit, please send us an email at office@bizhubreset.com or visit our website, http://www.bizhubreset.com
Aug 21, 2014 | Office Equipment & Supplies
My documents coming out faint when printing or photcopying what could be the problem?
The toner could be empty
or transferbelt/roller could be end of life
Jan 16, 2014 | Ricoh Aficio 1018 Printer
How to clean transferbelt in bizhub c220
Remove the transfer belt unit,remove the upper cover and used a vacum cleaner,cleaning under transfer belt cleaning belt section.
Jan 26, 2013 | Konica Minolta Bizhub C220 Color Copier
My lexmark is giving oerro 83 it is a C522
Error 83 indicates a problem referring to the transferbelt. Order a replacement transfer belt. When print quality is reduced, installthe new transfer belt using the instruction sheet that comes with the replacementtransfer belt. For further assistance, please contact LexmarkTechnical Support.
May 10, 2011 | Lexmark C522n Laser Printer
Replacing a transfer belt on a Konica BizHub C500. How do you replace it? Or which side of the transferbelt unit do you remove?
if i remember right, open right door, remove 2 tbu lock scews, open left cover, remove waste box and then remove tbu
Dec 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub c 250
Run stabilizer and gradation. Also check color registration.
Nov 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Installation of the transferbelt on samsung clx-3160fn
take drum out,carefully pull transfer belt which sit on top of drum.see how it is install remove and slide new one in.
Oct 05, 2008 | Samsung CLP 300 Laser Printer
HP Color LaserJet 2600n Printer Logo
136 people viewed this question
Clive
Clive
Thomas F. Schneider
