Question about Home Meridian Comfort Lift Recliner
Hand control for the lift chair lights are all flashing . and will not work
Lazy Boy hand control 8-pin not working to lift chair
The hand control may have failed but check for damaged hardware and connectors underneath.
Jul 24, 2016 | Furniture
Tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 | Health & Beauty
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Lift chair will not go up or down
Here's the manufacturer's phone #
1-800-994-3390 Reviews state that the hand controllers fail a lot and the parts department is slow.
Jul 26, 2014 | Home Meridian Comfort Lift Recliner
Hand control
Try Home Meridian Parts department.........
Mar 24, 2014 | Home Meridian Comfort Lift Recliner
Hand control for meridan chair
Try calling Home Meridian......Here's the manufacturer's phone #
Feb 28, 2014 | Home Meridian Comfort Lift Recliner
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
My Golden Technologies Comforter Series recliner/lift chair won't recline or lift. The buttons light up but nothing happens.
With Golden Technologies chairs, there is a self diagnostic system. There are LED lights at the transformer and the hand control. If you do have have lights at the transformer, it may be a power issue or a bad transformer. If you have lights at the transformer but not the hand control, it is the hand control. Since you state you ahve lights on the hand control, it is probably a motor issue.
The best thing you can do is call the store which sold you the chair or call Golden directly at 1-800-624-6374. While they do not sell directly to the public, they can point you to a local dealer who can help with the repair.
Sep 16, 2011 | Golden Technologies PR 501T 28D Comforter...
Lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Apr 10, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Home Meridian Comfort Lift Recliner Logo
55 people viewed this question
Top Home Meridian Furniture Experts
Peter
Peter
Tom Chichester
MobilityRepairSpecia...
Level 1 Expert
Are you a Home Meridian Furniture Expert? Answer questions, earn points and help others
