Question about Asko 24 in. D3350 Dishwasher
D3350 won't start wash
Asko D3350 won't start wash cycle. There are no fault indicators. On start up dishwasher fill but doesn't begin wash, timer continues going through cycle. Water supply is good, drain is good and pump is working. Faulty power board or something more simple?
Timon90
  • 126 Answers
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
VOTIT
  • 2071 Answers
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
Posted on Sep 14, 2008
SOURCE: ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Posted on Jan 19, 2009
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
Dec 31, 2010 | Asko Dishwashers
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
D3350 F4 indicator
F4 This is a Fault with the water fill
Note: Lights blinking, pump running and controls dead indicates an over fill fault
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find that it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. The drain hose must run up to the top of the underside of the counter top then down to the drain. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Aug 05, 2009 | Asko Dishwashers
Asko D3350 code F7
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
D3350 - Code F9
F4 problem
f4 fault means set to time fill,turn power off wait 5 sec then press and hold prog and start buttons in and turn power on wait for previos fault to show then release.then press the programme button the dishwasher will show 1 and start filling,press and hold prog button until it stops filling then press prog button until 4 shows on display,then press start finished,turn off then on and test on cycle.
Aug 15, 2007 | Asko 24 in. D3350 Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
29 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
