Question about Sharp LC46SB57UN 46 in. LCD HDTV
Downloading update for sharp tv model LC-46SB57UN on usb flash drive
Don't know how to do it
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 16 Answers
SOURCE: I downloaded on my USB the firmware update for my
yes
Posted on Nov 02, 2009
satavlad
  • 405 Answers
SOURCE: where can I download a updated software driver for
If you refering to firmware upgrade- there is non avalable for this model.
Posted on Nov 05, 2009
satavlad
  • 405 Answers
SOURCE: when I turn on my
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Posted on Oct 20, 2010
How do I download latest firmware onto my Sharp Aquos LC-52LE640U?
hi does your tv have usb port if so, go to the sharp website look enter the model number of your tv look for firmware for your tv download it, then load it on to a usb flash drive, thanks
shaun
Mar 16, 2017 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
I need to update my TV Sharp LC-37LE320
Just download the update via sharps website then upload to a flash drive and plug the flash drive into the usb port on the tv. Then go to the tvs menu to update from usb.
Jul 23, 2016 | Sharp Televison & Video
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
How do I update the firmware on my sharp lc-37rd2e I have a problem with hdmi on wii cosole I am currently on version 1.04
Get the update from Sharps website. Load it on an EMPTY formatted usb thumb drive. From he setup menu on the TV select software update.
Dec 29, 2014 | Sharp LC-32SB24U 32 in. LCD TV
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
Jun 04, 2017 | Sharp LC-32SB24U 32 in. LCD TV
HELLO,JUST I NEED TO THE FIRMWARE FOR MY TV SHARP LC-32D44U.HOW I CAN GET IT THE FIRMWARE? THANK YOU.
Here ya go:
  1. Download the latest firmware HERE
  2. Format a USB memory stick to FAT16
  3. Copy the contentse of the firmware zip file to the root of the USB memory stick (Root is the first view you see when you open the drive)
  4. Plug the drive into the TV
  5. Go through the TV menu and find the update firmware option
  6. Pray the power doesnt go out
May 09, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
Sharp LC46SB57UN 46 in. LCD HDTV Logo
95 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
