Question about Dell POWEREDGE 2900 Server
Installing geforce 6200 nvidia in dell poweredge 2900
  • 130 Answers
SOURCE: Windows 2008 and Dell PowerEdge 1300
yes
Posted on Jun 21, 2009
  • 110 Answers
SOURCE: Can ubuntu be installed on dell poweredge 2850
yes Ubuntu can be installed in Dell poweredge 2850 server
Posted on Oct 30, 2009
  • 39 Answers
SOURCE: I have an issue with the Dell PowerEdge 1800 video
Hi ngot01
Not knowing your application or tasking for your server, i cant make a full recommendation. I'm presuming you are not wanting to use this for a gaming machine.
One very determining factor is whether you are running 32bit or 64bit version of 2003. there are some fairly decent choices for cards but some won't support both 32 and 64 bit versions. If you have a particular card in mind, i would recommend first going to the manufacturers website and checking for compatibility with server2003
The geforce 5200 and 5500 from EVGA, PNY both come in PCI version with 128MB or 256MB onboard.
They are getting harder to find but are still to be found for a reasonable price online. i run a 5500 in one of my IBM X series servers dual processor with no hitches and no stability issues.
(32bit/64bit.)
32 bit support using older Nvidia drivers from Nvidia driver archives.
64 bit drivers currently available in latest Nvidia drivers version
The Visiontek Radeon 9250 PCI (ATI chipset) also runs well in both dell and IBM servers from my experience, and comes with 128MB or 256MB onboard.
64 bit support with current ATI drivers
32 bit support from older driver packages found on net.
One of the biggest considerations is whether the card will be properly recognized at first. Video cards and other peripherals behave differently in a server than in a desktop. Just dropping any PCI video card in may cause you some grief in time spent troubleshooting.
Another very important consideration is the video memory on the card.
Your 1800 requires ECC registered memory, but the onboard video memory on the video card can cause a problem when it starts trying to share the system memory. Not always, but this can cause a number problems, most common are blue screens.
Again, without knowing which version of 2003 you are running, i cant offer much more sound advice, because that is the biggest determining factor.
hope this helps, and if i have helped you, please dont forget to rate.
Posted on Feb 20, 2010
damneddle
  • 1607 Answers
SOURCE: how to remove cooling shroud
Hello
To do that you need to:
Turn off the system, including any attached peripherals, and disconnect the system from the electrical
outlet. Then open up the system.
To remove the cooling shroud, release the blue latches on the shroud by pulling each latch outward
from its securing tab.
Lift the shroud straight up to disengage the fan connector from the system board, and then lift the
shroud out of the system.
If you want the instructions with pictures, please click the link below and refer to pages 79-80:
Dell 2900 series Power Edge
It is in PDF format, if you can not open it please download and install free adobe reader by clicking this link:
Adobe Reader
Posted on Aug 31, 2011
  • 181 Answers
SOURCE: PXE-E61 failure while booting Dell poweredge 2900 server
Its a Network boot process ( Earlier Boot Rom ) Disable in BIOS setup or Ignore it, install OS and use server.
Posted on Apr 11, 2012
Geforce 6200 / dell dimension 4600 resolution problem
if this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto www.nvidia.co.uk and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Feb 02, 2010 | XFX GeForce 6200 Graphic Card
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
Which is better, the NVIDIA GeForce4 MX Integrated GPU or the NVIDIA GeForce 6200?
The 6200 has dedicated memory and being a several years more recent design is easily the better of the two.
Oct 04, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Game play is jerky installed new geforce 6200 on dell dimension 3100 with xp. played fine with old geforce 5200 fx.
Make sure that you removed the old graphic drivers and installed fresh ones from Nvidia. You can get to the drivers page from this Link.
Jul 12, 2009 | Luxor Amun Rising for Windows
We bought a Nvidia GeForce 6200 and once we connected to our monitor everything got really big, there was no start button, and when we went to change the color it got really blury and we couldn't change it...
What you have to do is this: Insert the 6200 card. Boot the computer, do not change ANY settings. Go to this site: http://www.nvidia.com/Download/index.aspx?lang=en-us select these options: Product type: GeForce Product Series: GeForce 6 series Operating System: Your operating system. And your language. Then click Search and download the driver. Install it, and then change your screen resolution in Windows' Control Panel. Everything should work fine after that. I hope this helps, Yannick.
Jun 05, 2009 | Dell Computers & Internet
I have a e-GeF0rce 8600 GTS. My computer sees a NVIDIA GeForce 6150SE N FORCE 430.0. iS THIS A PROBLEM
Hello Baldarchi,
This is normal and how ever uninstall the current driver and install latest driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Nvidea%20video%20driver.exe
The above driver supports:
[DEV_0098] NVIDIA GeForce Go 7800 [DEV_0099] NVIDIA GeForce Go 7800 GTX [DEV_00C8] NVIDIA GeForce Go 6800 [DEV_00C9] NVIDIA GeForce Go 6800 Ultra [DEV_00CC] NVIDIA Quadro FX Go1400 [DEV_0144] NVIDIA GeForce Go 6600 [DEV_0146] NVIDIA GeForce Go 6600 TE/6200 TE [DEV_0148] NVIDIA GeForce Go 6600 [DEV_0149] NVIDIA GeForce Go 6600 GT [DEV_0164] NVIDIA GeForce Go 6200 [DEV_0166] NVIDIA GeForce Go 6400 [DEV_0167] NVIDIA GeForce Go 6200 [DEV_0168] NVIDIA GeForce Go 6400 [DEV_01D4] NVIDIA GeForce Go 7350 [DEV_01D6] NVIDIA GeForce Go 7200 [DEV_01D7] NVIDIA GeForce Go 7300 [DEV_01D8&SUBSYS_81E6104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81EF104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81FD104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_8205104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_820F104D] NVIDIA GeForce Go 7400 [DEV_01D8] NVIDIA GeForce Go 7400 [DEV_01DA] NVIDIA Quadro NVS 110M [DEV_01DB] NVIDIA Quadro NVS 120M [DEV_01DC] NVIDIA Quadro FX 350M [DEV_0244] NVIDIA GeForce Go 6150 [DEV_0247] NVIDIA GeForce Go 6100 [DEV_0297] NVIDIA GeForce Go 7950 GTX [DEV_0298] NVIDIA GeForce Go 7900 GS [DEV_0299&SUBSYS_309F103C] NVIDIA Quadro NVS 510M [DEV_0299] NVIDIA GeForce Go 7900 GTX [DEV_029A] NVIDIA Quadro FX 2500M [DEV_029B&SUBSYS_309F103C] NVIDIA Quadro FX 1500M [DEV_029B] NVIDIA Quadro FX 1500M [DEV_029D] NVIDIA Quadro FX 3500 [DEV_0397] NVIDIA GeForce Go 7700 [DEV_0398&SUBSYS_81EF104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_8205104D] NVIDIA GeForce Go 7600 [DEV_0398] NVIDIA GeForce Go 7600 [DEV_0399&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 GT [DEV_0399&SUBSYS_8205104D] NVIDIA GeForce Go 7600 GT [DEV_0399] NVIDIA GeForce Go 7600 GT [DEV_039A] NVIDIA Quadro NVS 300M [DEV_039B] NVIDIA GeForce Go 7900 SE [DEV_0407&SUBSYS_01F11028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_01F21028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02281028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02291028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_022E1028] NVIDIA GeForce 8600M GT [DEV_0407] NVIDIA GeForce 8600M GT [DEV_0408] NVIDIA GeForce 8600M GTS [DEV_0409&SUBSYS_019B1028] NVIDIA GeForce 8700M GT [DEV_0409&SUBSYS_019C1028] NVIDIA GeForce 8700M GT [DEV_0409] NVIDIA GeForce 8700M GT [DEV_040B&SUBSYS_30C3103C] NVIDIA Quadro NVS 320M [DEV_040B] NVIDIA Quadro NVS 320M [DEV_040C&SUBSYS_20D917AA] NVIDIA Quadro FX 570M [DEV_040C&SUBSYS_30C5103C] NVIDIA Quadro FX 570M [DEV_040C] NVIDIA Quadro FX 570M [DEV_040D&SUBSYS_019B1028] NVIDIA Quadro FX 1600M [DEV_040D&SUBSYS_30C3103C] NVIDIA Quadro FX 1600M [DEV_040D] NVIDIA Quadro FX 1600M [DEV_0425] NVIDIA GeForce 8600M GS [DEV_0426] NVIDIA GeForce 8400M GT [DEV_0427&SUBSYS_01F11028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F21028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F31028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02091028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02271028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02281028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02291028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_022E1028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_9008104D] NVIDIA GeForce 8400M GS [DEV_0427] NVIDIA GeForce 8400M GS [DEV_0428&SUBSYS_9008104D] NVIDIA GeForce 8400M G [DEV_0428] NVIDIA GeForce 8400M G [DEV_0429&SUBSYS_01FE1028] NVIDIA Quadro NVS 140M [DEV_0429&SUBSYS_20D817AA] NVIDIA Quadro NVS 140M [DEV_0429] NVIDIA Quadro NVS 140M [DEV_042A] NVIDIA Quadro NVS 130M [DEV_042B&SUBSYS_01F91028] NVIDIA Quadro NVS 135M [DEV_042B&SUBSYS_01FE1028] NVIDIA Quadro NVS 135M [DEV_042B] NVIDIA Quadro NVS 135M [DEV_042D&SUBSYS_01FF1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024A1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024B1028] NVIDIA Quadro FX 360M [DEV_042D] NVIDIA Quadro FX 360M [DEV_0530] NVIDIA GeForce 7190M / nForce 650M [DEV_0531] NVIDIA GeForce 7150M / nForce 630M [DEV_0532] NVIDIA MCP67M [DEV_0533] NVIDIA GeForce 7000M / nForce 610M [DEV_053F] NVIDIA MCP67M
Sep 12, 2008 | Computers & Internet
Vedio controller GeForce 6200
XFX GeForce 6200, Graphic Card
driver dowunload
Aug 16, 2008 | XFX GeForce 6200 Graphic Card
Dell POWEREDGE 2900  Server Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
