Question about Sony KDL-32S3000 32 in. LCD Television
How to do a factory reset for KDL-40BX400 - Sony KDL-32S3000 32 in. LCD Television
Hello, I have an issue with a SONY KLV-40BX400, the TV turns on, displays the sony logo and plays the power on sound then turns off and turns on a few times and then doesnt turn at all and
If it is PLASMA TV.....
brandon barnes mentions..there is usually nothing physically wrong with 6 blink tvs..you need to reset the TV using the original remote
Not sure if the fix mentioned below is appropriate for your TV Sony eSupport Electronics Drivers Software
Aug 03, 2016 | Sony Televison & Video
Resetting my sony KDL-52V4100
Your tv probably has a remote. One of the buttons says "menu" or "settings". In one of those menues will be a reset to factory or default.
Feb 26, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
What can cause the sony bravia to switch on then off immediately.
6 flahes indicates a panel error possibly the backlight controller
Jan 31, 2014 | Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV...
Sony bravia model kdl-46z4100 has no sound. picture is ok.
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
Jun 11, 2011 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
I AM LOOKING FOR AN ENGLISH OWNERS MANUAL FOR THE SONY TV LCD KDL-40BX400
http://support.sony-europe.com/tvhc/tv/lcd/lcd.aspx?site=odw_en_GB&m=KDL-40BX400
This should be the manual you're looking for. You'll need a .pdf viewer (like Adobe Reader) to view it.
Mar 19, 2011 | Televison & Video
How do I reset a Somy bravia KDL-52W4100 back to factory default settings?
While holding down the UP arrow key, press the power button. The TV will turn off and back on and reset to factory default settings. Hope this helps
Jul 05, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
May 14, 2009 | Sony KDL-32S3000 32 in. LCD Television
Sony KDL-32S3000 32 in. LCD Television Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
