Question about E FUN Tablets & eReaders
Nextbook nx007hd How do you root
How do I get google play services on a nextbook tablet
Have a read of these and the video links in the main link at the bottom.
2.1 eclair - How do you fix your tablet if Google Play Services is ...
android.stackexchange.com/.../how-do-you-fix-your-tablet-if-google-play-services-is...
  1. Cached
  2. Similar
Nov 1, 2014 - How do you keep Google Play Services from stopping or get it to start back up? ... it instantly said "Google has stopped" so I reset the tablet by sticking a ... google-play-services nextbook-premium-8 or ask your own question.
How can I download Google Play to my Nextbook tablet? - MakeUseOf
www.makeuseof.com/.../how-can-i-download-google-play-to-my-nextbook-tablet/
  1. Cached
  2. Similar
Dec 27, 2012 - I bought a Nextbook tablet running Android, but I can't seem to get Google Play to download to it. The sales associate told me that Google Play ...
Google Play services - Android Apps on Google Play
https://play.google.com/store/apps/details?id=com.google.android.gms&hl=en
  1. Cached
  2. Similar
Rating: 4 - ‎10,084,970 votes - ‎Free Google Play services is used to update Google apps and apps from Google Play. This component provides core functionality like authentication to your Google ...
This app won't run unless you update Google Play services · Issue #37 ...
https://github.com/google/iosched/issues/37
  1. Cached
  2. Similar
Aug 15, 2014 - Update Google Play Services message on nexus5 with Android-L and ... Can someone please help I have a next book 7.85 tablet and the the ...
Unfortunately ,Google play services has stopped. - Google Product ...
productforums.google.com/d/topic/play/fqU5vZlybGk
  1. Cached
  2. Similar
Sep 20, 2015 - 100+ posts - ‎82 authors When I uninstall the update to Google Play Services the tablet immediately notifies that Google Play Music won't work without it, Google ...
How to Fix Unfortunately Google Play Services Has Stopped Problem ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
  1. Cached
  2. Similar
Dec 27, 2015 - 14 posts - ‎11 authors Friends, I rooted my Moto E xt 1022 & the problem started. I tried different solutions suggested in the post, but could not fix. I also restored. google play services on nextbook tablet Google Search
Jan 06, 2017 | Nextbook Tablets & eReaders
Instructions step by step on how to root nextbook area 8
Don't do it!
You are breaking the operating system at firmware level and no way to rectify when you decide that it is not all rooting is cracked up to be. You can reinstall the operating system, but there is no way to replace the IO information, the equivalent of the BIOS in a computer.
Dec 21, 2016 | Nextbook Tablets & eReaders
How to root nextbook 8 without pc
  • Download Kingroot. Download and install the Kingroot APK on your Android. ...
  • Launch KingRoot. Open your new KingRoot app. ...
  • Check for Button. Ensure that you can see the Start Root button at the bottom of the display. ...
  • Start Rooting. Tap the Start button to begin rooting. ...
  • Restart your Device.
  • Sep 21, 2016 | Nextbook Tablets & eReaders
    How to unlock a PUK tablet nextbook with a model named Premium 7 SE and model numbered : NX007HD ?
    Call your service provider and they will give you your PUK code once you have it enter it into your device and it should be ok then to turn the wifi back on
    Nov 25, 2014 | E FUN NextBook Premium NX007HD8G 8 GB...
    How to set memory card as default memory storage
    Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
    Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
    Nov 13, 2014 | Nextbook Tablets & eReaders
    How to unlock apps on nextbook
    1. Back up everything you feel is important before you start.
    2. Charge your device to 75% or more before you begin to prevent unwanted shutdowns.
    3. This method will only work for the versions of Nextbook 8 bought before August 2013. Check the back of the tablet and if the serial number begins with YFG1013, YFG1113 or higher, this procedure is not for you!
    II. Necessary Downloads
    1. SMT_Next8HD8G_Mod_Recovery.zip [Download link available in this post]
    2. Kyser_Root-signed.zip [Download link available in this post]
    III. Rooting the Nextbook 8
    1. Extract SMT_Next8HD8G_Mod_Recovery.zip to a folder on your desktop. You should end up with a file calleduImage_recovery with no extension.
    2. Connect your device to your PC and copy both uImage_recovery and Kyser_Root-signed.zip to your device's external SD card (not the internal memory, insert a microSD card if you don't already have one); do not put them into any subfolders just drop them in the main folder of your device's external SD card.
    3. Power down your device and reboot to the modified recovery you have just copied. To do this, with the device powered off, press and hold the Volume Up + Volume Down buttons with the Power button until you pass the splash screen, a black screen and you see the recovery menu.
    4. Use the Volume Up and Down buttons to highlight the 'Flash zip from EXT card' option and the power button to confirm the selection.
    5. Once flashed, go back to the main menu and select 'reboot system.'
    Once the Nextbook 8 reboots, check for the SuperSU app in the app drawer (install it from the Play Store if you don't find it) to verify you are rooted!
    Sep 29, 2014 | Tablets & eReaders
    Nextbook nx007hd
    try restart maybe it needs to reresh its storage devices and doesnt support hot swap
    Apr 18, 2014 | Tablets & eReaders
    How to root nextbook nx007hd
    1. Google and download Cydia Impactor (First result on Google) Extract it (desktop, wherever you prefer)
    2. Enable USB Debugging on your Tablet (Settings > Developer Options > USB debugging)
    3. Plug up your Tablet via USB, do not turn usb storage on, let windows try (and most likely fail) at installing drivers.
    4. Launch Impactor and select USB Driver Scan from the top menu (under USB). Let it do it's thing, reboot your PC after.
    5. Verify your tablet/android device is showing up on the start-bar as being plugged up/in (bottom right area)(this may not be needed depending on your setup)
    6. Relaunch Impactor (if rebooted ) and hit the Start Button
    7. Let it do it's thing.
    8. You should be rooted now go install SuperUser!
    Dec 17, 2013 | HTC PG41200 EVO View 7in LCD 4G Tablet
    Tablets & eReaders Logo
    194 people viewed this question
    Top E FUN Tablets & eReaders Experts
    William Alequin
     Mikey
    Mikey
    BrikimG
    Level 1 Expert
    Are you an E FUN Tablet and eReader Expert? Answer questions, earn points and help others
